all motor 428whp trying to go turbo
Hey ls1 tech friends i am in need of some Help and guidance to help me make my 99 ws6 ls1 To work with a 76mm turbo i was told that my set up wont work for a turbo what will i be able to use and what will i need to change.
My goal would be to b in the 700hp mayb if possible pls help
All upgrades done to my ls1
Engine came out a 2000 camaro 5.7 ls1 with t56
patriot tage 3 ls6heads cnc'ed ported and polished
tsp torque v3 cam 231/234 .643/598 111lsa
ls6 intake ported& polished tb also ported and polished
patriot gold valve springs(duals) 650 lift
ls7 lifters
cloyes double roller timing chain
melling high pressure oil pump
arp head bolts
hardend push rods tsp
160* thermostat
42#injectors
pacesetter long tubes
asp under drive pulley
monster stage 3 clutch
tick master clutch cylinder
ls7 lifters
arp head bolts
160* thermostat
42#injectors
What size injectors should I get and what turbo cam will work " do you know of any specific kind of that you would recommend "and I'd like to get a cam that sounds like mine basically I don't want to sound stock I want to hear a lump if that's possible I also plan on using 317 heads and ls9 head gaskets with arp head studs
maybe consider a better intake too. just an idea since youre looking to make some serious power.
https://ls1tech.com/forums/forced-in...urbo-ls-2.html
like everyone said above, you will need atleast 80lb injectors. i just put down 746rwhp on my ls1 5.7 with a torquer v2 cam on a 112lsa and an on3 performance 78/75 turbo. not sure what your compression is with those heads but that could be your limiting factor if youre running pump gas and trying to make 700hp.
