power window issues
power window issues
Hi guys I have a 1999 camaro SS and just replaced 2 power window motors, both passenger and driver side. Both are AC DELCO replaced them, both worked perfect. 3 days ago my driver side window has stayed down, however my passenger side window goes up and down freely since the wiring for the driver side is connected on the same plug. Bought a new switch still nothing. It cannot be stuck because I do not hear any noise coming from the actual motor when wanting the window to go up, any body else experience this problem if so what can it be thanks guys!
What switch did you replace? drivers? passengers?
I would pull the door panel and make sure you don't have power at the driver's window motor when switch is used.
It is possible the New motor is bad.
--Kyle
--Kyle
