Which driveshaft for 460le and dana s60?
My car has a Three rivers driveshaft 125640033 on it currently. It also has a Dana Strange S60 rear. I'm assuming that whoever installed it had to shorten the stock drive shaft by 1.625 inches to get it to fit and that they also use a u-joint conversion to go from 1310 to 1350?
In any case, I need to upgrade it.
I was thinking about a PST sportsman 3.5" aluminum but after the slip yoke upgrade it's like $500 shipped. Was hopping to keep this upgrade under 300 and have it bolt right in. Any other recommendations?
Can you call both places and ask them? I'm thinking I wouldn't want people I don't
know to give me there opinion or wild guess on something like a drive shaft.
If you are up there in power to where you need to upgrade your driveshaft
surely you wouldn't cheap out on it. just my .02
LS1Tech Premium Sponsor
Give us a call... We sell a ton of driveshafts from both Strange and PST, we can give you the right specs and correct yoke selection for your particular needs.
Keep in mind there can be a good difference in the quality of the trans yoke that will affect the strength and vibration of the new shaft. We typically use a higher quality USA slip yoke than others that sell the same shafts and it makes a world of difference when you are considering high speed vibes. We also guarantee the lowest prices at the same time so you get the best possible deal with MWC.
