Pulling heads, should I swap lifters?
Just what the title says. I'm pulling the heads to chase down a suspected coolant leak and figured since I have the heads off, should I swap the lifters? They're stock as far as I know and have about 161k on them. If I do swap, should I go with just some ls7? I was planning a build in the far future, and was planning on getting some morel 5315s for that build. Would it hurt to get those early?
I do have a tick, though I think that has more to do with a bad pickup tube o-ring than a collapsed lifter though.
If you have the money I'd go ahead and do it since the heads will be off. I originally was going with the ls7's, but I've been hearing more stories about some failing, so I'm going with Morel's.
