Is there an epoxy stronger than JB Weld? - LS1TECH
Thread Tools Search this Thread
Old 06-13-2004, 12:44 AM   #1
Default Is there an epoxy stronger than JB Weld?
I need to fill a small hole in an aluminum part. JB Weld can crumble. There must be a product that is stronger then JB Weld.
shep28 is offline   Reply With Quote
Old 06-13-2004, 04:29 AM   #2
99ta's Avatar
Try a epoxy called Super Mend it works very well and is a lot stronger. It comes in a yellow and white box w/red writing. I have gotten it at Ace hardware.
99ta is offline   Reply With Quote
Old 06-13-2004, 08:26 AM   #3
What is this for?
Depending on what the part is and how large the hole is, patching or puddle-filling the hole with a TIG could be much better ideas than an epoxy.
As far as epoxies go, I'd recommend Master Bond's EP22. SuperMEND is only good for intermittent exposure to 150 F, and it's not terribly strong. If you're a fan of SuperMEND, the same company (GOOP), makes an epoxy called "SuperWELD" that is much more durable and probably wouldn't be a bad choice, either.
Every type of epoxy has different properties. It's kinda hard to recommend something without knowing what the part is and what sort of environment it's gonna see...
Rhysamedrae is offline   Reply With Quote
Old 06-13-2004, 11:31 PM   #4
Racehead's Avatar
Belzona is the strongest 2 part epoxy style product made and is used to patch holes in blocks and other similiar things and is drillable and tappable. It's regularly used in the trucking industry. It makes JB weld looks like a childs product.
Racehead is offline   Reply With Quote
Old 06-14-2004, 08:19 AM   #5
technical's Avatar
I've never tried it, but it looks like a decent product...
http://www.alumaloy.net/
technical is offline   Reply With Quote
Old 06-14-2004, 08:59 AM   #6
koolrayz's Avatar
Quote:
+1 for belzona its an industrial product that is outstanding. You will want to use the R-METAL style. hang on to your check book when you see the price
koolrayz is offline   Reply With Quote
Old 06-14-2004, 10:15 AM   #7
Moderator
jimmyblue's Avatar
I think it depends more on the hole's particulars
than the epoxy. Like, forget having anything
plug a hole in sheet metal or thin-wall casting
permanently, thermal expansion cycles will bust
it free eventually.
Never seen JB fail myself; under what use has
it "crumbled"?
If you're looking to (say) plug a TB blade hole,
then peening in a soft aluminum plug or doing
a quick weld-blob would be more likely to last.
On thicker stock, tapping the hole and putting
an epoxy-set pipe plug (or Allen screw for small
jobs) might be better than epoxy alone - at
least you have some mechanical "keep".
jimmyblue is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Is JB-Weld safe for interior panels like the spare tire cover? Jeff 97 Formula Paint & Body Work 14 03-25-2014 02:57 PM
what have you fix with JB weld tomz28 Western Members 20 05-11-2009 03:51 PM
JB weld cherryelky305 Racer's Lounge 9 04-28-2008 02:41 PM
JB Weld? travisnd Tools & Fabrication 38 04-21-2006 04:10 AM
jb weld question spdracer Appearance & Detailing 13 07-19-2005 11:45 PM
Tags
belzona, epoxies, epoxy, good, goop, jb, mend, prices, rmetal, stronger, super, superweld, tappable, weld, whats, yellowing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
