5.3 Juankyard Build. Answer please.
Old 04-23-2016, 04:42 PM
92_obs's Avatar
Default 5.3 Juankyard Build. Answer please.
Like it says im brand new to this.
Ive got an 02 5.3 from some guy off craigslist for $200. Block/Heads/Crank/Rods/Oilpan/NoSensors. I want to put it in my 92 Ext cab Silvy to take place of the 350. As of now my 350 isn't blowing up soon so I want to put the 5.3 on an engine stand and build it throughout the time. Ive done tons of research for the past 6 months before buying the engine. And I want opinions if the parts list I have will work as a DAILY and a weekend warrior.
Intake: Truck manifold
Throttle Body: Aftermarket 80mm TB
Injectors: 60lb siemens
Fuel Pump: Walbro 400
Heads: 706 heads
Valvesprings: LS6
Pistons: OEM cup dome pistons
Rods: OEM 143 connecting rods
Crank: OEM 5.3 crank
Harness/Comp/Etc: NOCLUENEEDHELP
Turbo/Bov/WG: On3 76mm, 50mmBOV, 44mmBOV
ARP main stud Kit/ ARP head bolt kit
LS9 Head Gaskets
Pushrods: 7.425 pushrods
Camshaft: LS6 camshaft
Lifters: OEM Lifters
Rockers: OEM 1.7 ratio Rockers
Old 04-23-2016, 05:05 PM
92_obs's Avatar
How do I post pictures with my thread as well I couldn't figure it out
Old 04-23-2016, 11:43 PM
92_obs's Avatar
anybody??
Old 04-23-2016, 11:52 PM
SweetNova's Avatar
Use a site like tinypic and use the link for forums link.
1. Upload to TinyPic
2.Copy Forum code
3. Paste code into box
4. Post thread
Old 04-24-2016, 01:15 AM
92_obs's Avatar
2.Copy Forum code
4. Post thread
awesome thanks. and just wondering do you have any input in my parts list choices? I just want to be correct before actually throwing down cash.
Old 04-24-2016, 02:54 AM
kingtal0n's Avatar
do not open the engine until you have everything you need for it, then, plan carefully every step what you intend to do, then do it all in one shot when you have every part ready. Close the engine up fully when not working on it if there is any delay. Do not leave an open crankcase to the atmosphere for days/weeks sitting in a corner while you "build it"
use mostly OEM parts for longevity/reliability (oem cam grind, oem springs, looks like you already have that figured out)
Old 04-25-2016, 02:45 PM
jamescallowa's Avatar
True I made that mistake. My rebuild took a month, fortunately I didn't have any issues.
Old 04-25-2016, 05:04 PM
HotRodLS1's Avatar
What are you responding to?
Telling you're planning on buying an LS engine, telling you have an LS7 one hour later and posting messages like this doesn't make you very creditable.
Quick Reply: 5.3 Juankyard Build. Answer please.
