Wire harness question
Hey. I have chance to get a wire harness for my build. However both wire harness I can get are 4x4. Will a 4wd wire harness work on a 5.3l 4l60e 2wd.? My build is drive by cable also both wire harness are drive by cable also.
Thanks
Thanks
Restricted User
Just plugs for T case and one for front axle.
All you have to do is unpin the wires from the ECU connector and pull them out.
They're all on the red connector from what I remember. Pins 16 and 19. The rest all go to the larger plugs that connect to the firewall or fuse box.
