Wagon 5.3ls swap
Wagon 5.3ls swap
Hello everybody! I'm new to the ls world and and looking for some guidance. I'm planing to start a wagon ls build very soon and have never done this before so I have alot of questions. If anyone could help me out it would be much appreciated. I don't want to spend a ton on the build but I also want it to last so if I have to save I will. First off it will either be a 67-70 Malibu wagon, 67-70 pontiac tempest wagon or 78-79 Malibu wagon. I'm open to anything ryl just depends what I can get that the body is is good shape. I want to make around 550-600whp. I have decided on the cam and turbo already but everything els I'm looking for advice. The cam I chose was a Lil John motorsports turbo cam stage two and the turbo was a s475 borg unit 1.32ar as the 1.1.ar is just to expensive for me. I forgot to mention once it's built and the bugs are worked out I plan to daily it as my primary vehicle. Also will be using megasquirt as the harness. Intended to use the factory heads on whatever engine I get. If you all have any recommendations on springs, pushrods, gasket kit, bearing kits, trans(auto or manual), rear diff, intercooler, pistons, rods, crank, motor mounts ect please let me kno. I literally kno nothing in swapping a LS buy have many years of experience and school in automotive technology so u may have to be very descriptive for me to understand lmao. But again any help is greatly appreciated and thanks!
Restricted User
Smaller cam, smaller turbo. Neither of those is necessary at all.
550whp is possible on a 100% stock 5.3 long block without ever removing the valve covers. 05+ have stronger rods and will handle much more.
If you want to actually finish this and do it cheap, you can skip upgrading 99% of the things you listed as long as what you do change is done right.
Oh nice! Good thing I asked before hand!! What would u recommend? I plan to get a junkyard engine so just do a basic full rebuild and a smaller turbo? Like a s400 turbo or even smaller?
Restricted User
If you buy an engine that you've never heard run, I would do the usual.
Replace the lifters, head gaskets, and possibly head bolts (your preference, I typically don't). If you want to shift the powerband around, grab a cam. I would go with something small for such a modest power goal. Something that will shift the powerband around a little bit.
Something a little closer in size to this: https://www.summitracing.com/parts/h...make/chevrolet
For me, I usually choose camshafts based on which transmission is being used. A TH350 for example will shift much earlier, so I usually go with a cam that hits harder down low.
If you want an S475, get the small wheel version. 83mm, not the 96. They're the same price. Maybe spend a few extra for the T4 version. I guess it depends on where you want it to make power.
LS1Tech Administrator
Received 1,483 Likes
A TH350 can be built (governor re-calibration kit and such) to shift higher, so there would be no reason to limit cam options to only those that are ideal for stock shift points. Options such as a ratchet shifter can also be used for precise manual control over upshift rpm at WOT, allowing a stock shift pattern for part throttle operation via the governor, if so desired.
What do u guys recommend turbo wise? Since the s475 is overkill what would be more reasonable for 550-600w?
Restricted User
When that's the case, I don't dare go with something with a 115+ LSA unless I'm asked to. Usually very mild 22x/22x duration and a 111-112 LSA depending on engine. 5.3s with a TH350 usually get no bigger than the 222/225 .560/.570 112. 4.8s get the 214/220 .550/.560 112 LSA.
OP, basically, don't let the engine pick the cam, let the whole setup pick the cam.
