Do I need a tune?
Do I need a tune?
I bought my car on 22's but I have since switched over to 17 inch rims, but now the speedometer is off by 5 to 10 mph depending how fast I'm going. I plan on putting 342 gears in the Car soon also, So how exactly do I adjust speedometer?
I also plan on running headers no cats in a cut out soon. Will attuned keep my check engine light from coming on when I take the cats off?
And if I do do a tune, what kind of power can I pick up from it?
Most likely it would just be a program to know what someone in town do, but maybe a Dino tune. Also should I get the cartoon to 93 octane?
LS1Tech Administrator
Received 1,486 Likes
Not very much if the car is otherwise completely stock, but it's definitely worth it after the headers. For now, the main benefit will be getting the speedometer corrected.
on a stock car you wont pick up a lot of power unless the tuner is using a wideband and gets fueling optimized and is able to add a fair amount of timing advance but it still wont be a huge amount as far as max #'s you would see on a dyno. Where the most gains will be is from removing torque management (which limits power at pre determined times like during shifts) , increasing rpm's a bit for WOT shifting , verifying throttle bodyis opening all the way and mechanically adjusting until the tps values show it is indeed fully opening , adjusting downshift and upshift data , shift pressures ,etc... to just feel tighter and more aggressive.
The speedometer/tire calibration stuff is simple , tuner will just go to the speedometer tab and enter new gear ratio in the gear ratio field and choose the tire size from a drop down and apply. tuning out the dummy light for no cats is just changing a check mark as to how it reports.
I did a cam and long tubes (full exhaust) only on a stock ls1 and hit 368rw and 375tq. This was a 91 octane tune from a dyno.
My check engine light did not come on with no cats, but could happen.
