looking for an oil cap for valve cover with two tabs
Anybody know of a cap that attaches directly to the valve cover with 2 tabs? I removed the extended filler neck and just now learned that the valve cover has 2 tabs, but the original cap only has one slot for one tab.
Also looking for the same two tab filler next part number for my 2011 L94
I'll have a look at my old LS3 covers and see if there is something I can find. Could you post a picture of what you need?
I ended up making my own oil cap out of a vent cap. Shaved it, cut the rubber to fit, sealed it, and added fittings for a vacuum blowoff valve and vacuum line for my vacuum pump.
This doesn't sound like an over complicated thing if you end up having to make something. Grommets go a long way here.
Just had this issue, google or ebay
GM Oil Fill Tube 12609623
https://www.ebay.com/itm/10-14-LS3-L...087?rmvSB=true
The above is the link someone offered me. I had to do some digging to find the part number and get it cheaper.
I have a 2011 6.0 ltr with a two tab valve cover. I didn't want to grind off the tab on the valve cover so I used a couple different dremel bits and ground the cap to accept the second tab.
Before my dremel attached the cap
After a little grinding. Fits snug. I'll have to wait and see how well it seals.
