Need help with missing RPO codes
Old 07-22-2004, 01:25 PM
SLPSS01's Avatar
Default Need help with missing RPO codes
Where is a good source to look up RPO codes for a 2001 Camaro SS ?
I found this site :
http://camarossworld.com/Production%20Numbers/RPO.asp
but it appears there are some codes in my RPO not listed there.
Old 07-22-2004, 04:19 PM
jrp
SN95 Director
jrp's Avatar
uh, how about you tell us which codes your missing
Old 07-23-2004, 05:40 PM
Danny2tek's Avatar
Old 07-23-2004, 07:59 PM
Azrael's Avatar
RPO Production Codes
Code Description
AG1 Adjuster, 6-Way Power, Driver Seat
AG4 Adjuster, 2-Way Manual, Driver Seat
AH3 Adjuster, 4-Way Manual, Driver Seat
AK5 Restraint System Front Seat, Inflatable, Driver and Passenger
AN4 Restraint Provisions, Child
AQ9 Seat, Passenger and Driver, Recline
AUO Lock Control, Remote Entry
AU3 Lock, Side Door, Electric
A31 Window, Power Operated, Side
A90 Lock, Rear Compartment Lid, Remote Control, Electric
B35 Floor Mats, Rear, Carpeted Insert
B84 Exterior Molding, Body Side
CC1 Roof Hatch, Removable Glass Panels
C41 HVAC System, Heater
C49 Defogger, Rear Window Electric
C60 HVAC System, Air Conditioner, Manual Control
DD9 Mirror, Outside, LH & RH, Remote Control, Electric, Breakaway, Painted
DE4 Sunshade, Removable Hatch Roof
DG7 Mirror, Outside LH & RH, Remote Control, Electric, Painted
DL5 Decal Roadside Service Information
D35 Mirror, Outside LH Remote, RH Manual, Painted
D82 Paint Special
FE2 Suspension system, Ride handling
FE4 Suspension System, Special Ride and Handling
FE9 Certification Emission, Federal
F41 Suspension System, Firm Ride Handling, Front and Rear
GU2 Axle, Rear 2.73 Ratio
GU4 Axle, Rear 3.08 Ratio
GU5 Axle, Rear 3.23 Ratio
GU6 Axle, Rear 3.42 Ratio
G80 Axle, Rear Posi-traction (Limited Slip)
ILD Trim, Interior Design
IL2 Trim, Interior Design
IPB Trim, Interior Design
IP2 Seat, Leather Sport Front Bucket, Driver & Passenger, Reclining
J41 Brake System, Power, Front Disc, Rear Drum, Cast Iron
J65 Brake System, Power, Front and Rear Disc
KG9 Generator, 140 Amp
K05 Heater, Engine Block
K34 Cruise Control, Automatic Electronic
K43 Generator, 102 Amp
K68 Generator, 105 Amp
LT1 Engine, 5.7L (V8) MFI
L36 Engine, 3.8L (V6) MFI
MM5 Transmission, 5-Speed Manual (Merchandising Option)
MM6 Transmission, Manual, 6-Speed, Borg Warner, 65mm, 2.66 1st, 0.50 6th, O/D
MN6 Transmission - 6-Speed Manual (merchandising Option)
MXO Transmission - Automatic O/D (Merchandising Option)
M30 Transmission - Automatic, 4-Speed, 4LE, Electronic
M49 Transmission, Manual, 5-Speed, Borg Warner, 77mm, 3.75 1st, 0.76 5th, O/D
NB6 Emission System, California Requirements, Tier 1
NC3 Tailpipe Modifications
NF2 Emission System- Federal Requirement, Tier 1
NK3 Steering Wheel, Sport, Soft Rim, Simulated Leather
NP5 Steering Wheel, Leather Wrapped
NW9 ASR Traction Control
N36 Steering Wheel, 4-Spokes, Sport
N60 Wheel, Aluminum, Painted
N73 Wheel, Custom Sport Var4 17" (Restricted to Camaro SS)
N92 Cover, Wheel, Bolt-On
N96 Wheel, 16x8, Cast Aluminum
N98 Wheel, Chrome, Var 2
P05 Wheel, Chrome, Var 1
P08 Cover, Wheel, Super Deluxe
QA7 Wheel, 16x7.5, Aluminum
QB3 Wheel, 16x7.5, Steel
QEA Tire, P215/6OR16 BW R/Pe ST TL AL2 94T
QFK Tire, All P275/40R17 BW
QFZ Tire, P24515OZR16 BW R/PE ST TL AL3
QII Tire, P21516OR16 BW R/PE ST TL AL3 94H
QLC Tire, P24515OZR161N BL R/PE ST TL HW4
STE Plant Code-St. Therese, PQ, GM of Canada
TR7 Headlamps, Automatic Control Leveling System
T39 Lamp Turn Signal, Auxiliary
T43 Spoiler, Rear
T61 Lighting- Daytime Running
T96 Lamp, Fog
UA6 Theft Deterrent System
UB3 Instrument Cluster, Oil, Coolant, Temperature, Volts, Trip Odometer, Tachometer
UK2 Lever, Directional Signal, Multifunction
UK3 Electronic System Accessory Control
UL0 AM/FM Cassette ETR 200 Watt Monsoon Sound System w/cassette
UN0 AM/FM Cassette ETR 200 Watt Monsoon Sound System w/CD player
UN6 Radio, AM/FM stereo, Seek/Scan, Auto Reverse Music Search Cassette, Clock, ETR
UQ0 Speaker System 4, Dual Front Door Mounted, Standard Range Quarter/Shelf
UU8 Radio, AM/FM Stereo, Seek/Scan, Auto Reverse Music Search Cassette, HPS, Clock, ETR
UZ7 Speaker System, 8 Quat Frt Dr Mtd Dual RR Hatch Amplifier
U1C Radio, AM/FM Stereo, Seek/scan, Compact Disc, Clock, ETR
U1S 12 Disc Compact Disc Changer
U1T Radio, AM/FM Stereo, Seek/Scan, Compact Disc, HPS, Clock, ETR
U18 Speedometer Instrument Kilometers
U19 Speedometer Instrument, Kilometers and Miles, Kilometer Odometer
U62 Speaker system 4, Dual Coax Front, Dual Coaxial Package shelf
U65 Speaker system 5, Dual Front Door Mtd, Dual Ext. Range Panel, Single Rear Compartment
U73 Antenna, Fixed
U75 Antenna, Power
V12 Cooling System, Power Steering
VG8 Label, Vehicle, Notice to Buyer
VH5 Plate, Vehicle Information
VK3 License Plate, Front Mount Package
VP6 Noise Control
WS6 Performance Package - Formula/Trans Am
WU8 SS Performance Package/Appearance Package - Camaro
W51 Entertainment system - Radio, AM/FM-stereo, seek/scan, cassette, 4 Speaker system · Standard Range
W52 Entertainment System - Radio, AM/FM stereo, Cassette, Equalizer, 4 Speaker system - Coaxial
W53 Entertainment System - Radio, AM/FM Stereo, Compact Disc, Equalizer 4 Speaker System - Coaxial
W54 Entertainment System - Radio, AM/FM Stereo, Cassette, Equalizer, 10 Speaker System, Amplifier
W55 Entertainment System - Radio, AM/FM Stereo, Compact Disc, Equalizer 10 Speaker System, Amplifier
W57 Entertainment system - Radio, AM/FM stereo, Cassette, Equalizer, 4 Speaker system - Coaxial
W58 Entertainment system - Radio, AM/FM Stereo, Compact Disc, Equalizer, 4 Speaker system - Coaxial
W59 Entertainment system - Radio, AM/FM Stereo, Cassette, Equalizer, 6 Speaker System, Dual Front Door Tweeters/Woofers, Extended Range Shelf
W66 Merchandised Package - Formula
W73 Entertainment system - Radio, AM/FM Stereo, Compact Disc, Equalizer, 6 Speaker system, Dual Front Door Tweeters/Woofers, Extended Range Shelf
Y81 Merchandised Package - Firebird
Y82 Merchandised Package - Trans Am, Base Coupe
Y84 Merchandised Package - Trans Am
Y87 Merchandised Package - Performance Enhancement
Z28 Merchandised Package - Special Performance
Z49 Canadian Modifications
01U Primary Color exterior, Special
05Q Molding Color, Cyclamen
O5U Primary Color Exterior, Cyclamen
1LE Performance Package Components
101 Interior Trim - Arctic White
1OT Top Color - Arctic White
102 Trim Combination Leather, Arctic White
1OQ Molding Color - Arctic White
1OU Primary Color - Exterior, Arctic White
12B Trim Combination - Cloth, Graphite
12D Trim Combination - Cloth, Graphite
121 Interior Trim - Graphite
14B Trim Combination - Cloth, Dark Gray
1SG Preferred Equipment Group
28U Primary Color - Exterior, Navy Blue Metallic
1FP87- Camaro Coupe Z28
Old 09-14-2010, 07:39 PM
ANTICOP RAM AIR's Avatar
I have some missing codes from my 99 ws6.. been to four sites and filled in a few of the blanks but theses are nowhere to be found..... let me know if you can help..
CAF
IP3
PBT (POSSIBLE WHEEL TIRE CODE)
R7X
R9P
R9U
R9Z
T78 (POSSIBLE LIGHTING OPTION)
U75 PWR ANTENNA
V73 FIXED ANTENNA (I HAVE BOTH CODES ON STICKER, ONE PWR AND ONE FIXED ANTENNA???
6ZR
7ZR
8HS
I any help would be nice.. also i have no traction control button... were there 99 ws6 auto without TCS
Old 09-16-2010, 11:04 AM
2001NBMZ28's Avatar
You can get the missing ones at www.lonestarthunder.com
Old 09-16-2010, 11:50 AM
Danny2tek's Avatar
HOly thread resurrection!
Old 09-16-2010, 06:12 PM
Default rpo info
Thank you for that.. the codes i was missing were mostly bs dealer codes anyway..
that site is awesome, much easier than searching each code..
Quick Reply: Need help with missing RPO codes
