SS hoods
SS hoods
How can you tell a real SS hood from a fake. ALso, what were the factory SS hoods made out of. Were SLP hoods fiberglass or are they a thin metal layer or what. Plz reply asap.
if you look on the inside you will see two Ram Horn style passages that redirect the airflow to the factory airbox. the real SS hoods say MADE IN CANADA and have the Patent # as well .
Originally Posted by jrp
under the hood latches there are also 2 holes drilled for water to drain out. my aftermarket hood (dont know what kind) doesnt have those holes. theres also another difference but it escapes me as of now.
An actual SS hood is a lot heavier than most aftermarket hoods. I have a Suncoast hoo and it is very light even compared to the regular Z28 hood. The scoop on an original also tends to have a lower profile than many aftermarket hoods. The aftermarket hoods also have the horn shaped air passages. At least mine does. If it is a functional hood it should have these, for what function there actually is any way (not much). It's all looks!
Ok the SS hood is fiberglass, and the Z28 hood is metal so I dont think you can get that confused.
