Borla adjustable plate question
Old 08-01-2004, 12:19 PM
tryan24's Avatar
Default Borla adjustable plate question
I just got borla installed on my car yesterday and I think the previous owner was running the 2 inch plate. Well I want to run it wide open but I can't get the bolts off to save my life, I think he over-torqued them. Anyone have any ideas on what I can do to get them off or do I have to settle for the 2 inch plate being in there forever because of the dumbass that had it before me?
Old 08-01-2004, 03:33 PM
INMY01TA's Avatar
Bottom one should come out easier. Try putting a jackstand under the tip to support the whole thing then work on the top two bolts. Use penetrating oil (and elbow grease)of course.
Old 08-01-2004, 05:05 PM
ddelallata's Avatar
start with the nuts first. Then after they are loose you still have to unscrew the bolts; these are screwed on to the flange. Try some WD-40 or silmilar.
Old 08-01-2004, 05:50 PM
LPCWS6's Avatar
http://www.jcwhitney.com/webapp/wcs/...Id=-1&TID=1544 http://us.shop.com/amos/cc/main/cata.../adtg/07300441 http://www.northerntool.com/webapp/w...&productId=565
if you can't get them out
Old 08-01-2004, 06:48 PM
camaro99z's Avatar
If all else fails just take it to your local exhaust shop. They should be able to take care of it pretty easily.
Old 08-01-2004, 09:52 PM
skippytheloon's Avatar
I would hit the wrench with a hammer on the nut side to "jolt" it loose. Works on almost anything.
Old 08-02-2004, 09:53 AM
ricker6869's Avatar
My borla system has no "nuts" just bolts that go all the way thru the flange...what are you talking about.
PS. When I remove mine..I usually have to heat them with a gas torch..its makes its much easier..also use a long wrench for added leverage.
Rick
Old 08-02-2004, 11:43 AM
rdavis93's Avatar
when i removed mine from the 93, one of the bolts was crossthreaded when put in with air tools and I had to use a breaker bar to get the bizatch out. It came out broken, but out it came! Breaker bar that stuff!
Old 08-02-2004, 08:00 PM
Mine came with 3 bolts with nuts, washers and lock washers. Yep, tapping with a hammer breaks it loose while tugging on it breaks the bolt. Why not spray it with oil, torch it and tap it with a hammer!
Old 08-02-2004, 10:10 PM
99'Formula's Avatar
Spray some WD-40 on there and let it sit and then just use some elbow greese
