A/C problem
A/C problem
Took the BCOD on a trip to Austin this weekend and had a little problem with the A/C. It's blowing cold air, just not much of it. When I turn the fans up, I hear a "whirring" sound, almost like something is stuck when trying to open the dampers.
Any ideas on where to start?
Thanks.
-Mike
Thanks.
-Mike
wrencher
I would start at the motor. Pull the lower bolster pane out down at passenger footwell area. Then pull the cover off the blower motor & unbolt the motor from the HVAC case & remove the blower motor. See if some thing got inside there to hamper airflow.
I'll check that. Thanks for the advice.
Let me clarify a little more. I can hear the fans blowing harder, but the air coming our of the vents doesn't seem to come out any harder. Does that change the advice?
-Mike
-Mike
