how do u turn off traction controle?
uhh last time i checked you had to hit the button that says "TC S" it should be located right underneath the AC control pannel.
press it once to turn it off, and a light should come on in the instrument cluster thats says "TCS OFF"
tcs is on pontiacs and asr is on chevrolets...consider it a good thing that you don't have it...the tcs takes the place of your cell phone holder (not sure if that is its intended purpose but it works great)...yeah i was about to get upset when i read this cause it is completly obvious how to turn it off but seeing that you don't have it i can understand your confusion
if you have a light that comes on, on the dash when you spin the tires that says LOW TRAC then you have traction control. If not then you dont. I think there should be a code for it on your door. Otherwise you could prolly call a GM dealer and give them your vin and they could tell you.
BUT in all honesty, I dont see how you could have traction control with out having a button for it. I have a camaro, and I have an ASR button
Goodluck
Goodluck
The LOW TRAC light comes on whether you have traction control or not...it's a function of the ABS system.
Chevrolet = ASR located beneath the center dash vents
Pnotiac =TCS located next to the cig lighter
No button = No traction control...only ABS, which is standard on the Z-28 and SS.
Originally Posted by technical
You sure about that? When my TCS is off I won't get the LOW TRAC light when I sping the tires or bang second.
