Third Gear Not Pulling as Hard
Old 08-29-2004, 09:27 PM
hitemup9nine's Avatar
Question Third Gear Not Pulling as Hard
I have a 99 t.a. I have raced many other f-bodys and for some reason they all have a better third gear than me. I can be ahead a car and a half the first two gears and on third they close it up to half a car. What gives? The only thing they use that i dont is a kn air filter could this be it?
Old 08-29-2004, 11:01 PM
cyphur's Avatar
no....a k&n air filter is not going to give them a huge edge over you like that. what year are they? thats odd. tranny issues?
Old 08-29-2004, 11:10 PM
2_wacko's Avatar
Maybe they have newer car's that might be a reason. The 01-02 have a better pull than 98-01 but I might be wrong.
Old 08-29-2004, 11:30 PM
txhorns281's Avatar
not trying to call you out but could be the shifting??? the 1-2 shift is easy, but if you get a clean 2-3 shift (specially when powershifting) your pals can keep their RPMs up better and stay in their power band... Just a thought...
Old 08-29-2004, 11:44 PM
Well there's two particular ones a 99 and 00 camaro. All are automatics including mine and I leave mine in regular drive.
Old 08-30-2004, 09:30 AM
cyphur's Avatar
they're auto's? oh hmm. well do they have shift kits? or any sort of shift firmness programming? tc?
Old 08-30-2004, 04:08 PM
Nope. We both have headers, lid, and the camaro has a fast toys ram air and i have a bg ram air. So basically were the same. Could it be the weight difference (camaro vs. t.a.)?
Old 08-30-2004, 04:26 PM
777's Avatar
it could be a problem with your car...or so it seems to me...the weight shouldn't play into it at 3rd gear only...in fact it should be near the beggining...so i'd say you may have a problem with something....are all the same tune??
Old 08-30-2004, 04:56 PM
LoPeY's Avatar
Do you all have the 2.73 or 3.23 gears? That could have something to do with it although that should have an effect through every gear.
Old 08-30-2004, 05:27 PM
necrocannibal's Avatar
Do either of you have tuning?? If not then your cars tune could be off much more than the others. Headers make LS1s run really rich.
Old 08-30-2004, 05:56 PM
frey51's Avatar
Im going with gears. you probably have 2.73's and the others probably have 3.23's. There is a way to tell what gears your rear has from a code on your doorjam, but I dont know what it is. Might try searching for it.
Fry
Old 08-30-2004, 06:09 PM
GU5 is the 3.23 gear code I think. Not sure about the 2.73s, maybe GU2 or GU1.
Old 08-30-2004, 07:40 PM
Well we all have 3.23 gears and all of us have headers. I'm thinking my cars just out of tune more than theres is.
