wich wire for a/f guage hookup
Old 09-08-2004, 04:00 PM
1RawTA's Avatar
Default wich wire for a/f guage hookup
I know u can go right down to the 02sensor and hook it up, but i dont wanna do that... i need to know wich number out of the ecu u can hook it up too? i have searched around and people say it is the #69 wire wich is purple, but on my car the #69 is light blue, but i belive #67 is purple with a white stripe. any of you have an idea what i should wire it too
Old 09-08-2004, 04:11 PM
Z28Venom's Avatar
You're looking for the purple w/ white stripe..
Old 09-08-2004, 05:58 PM
1RawTA's Avatar
so ur sayting it is the #67 one then?
Old 09-08-2004, 06:47 PM
Z28Venom's Avatar
I'm not sure on the pin number, but I know that the wire is purple w/ a white line.
I tapped into mine right at front of the drivers side head.
Old 09-08-2004, 06:53 PM
Tranzaman00's Avatar
I used the pig tails that speed inc sells. This way is cool though no chance of burning the wire. Is the wire the same color on each bank you said you hooked to the drivers side what about the passenger side. No point in monitoring one side (bank) of the motor. I have one for each bank but then again I have been told that they don't do you any good as far as readings on factory o2's any way. I was told if you want true readings you have to hook them up to wideband o2's
