RPO Option Code Database
http://www.lonestarthunder.com/rpo/
I just converted a list to sql and php so its fully searchable just start entering your codes!
If you dont know what RPO codes are (not saying most of dont) they are the options your car came with on the door sticker, WS6, LS1, LS6, GU5, etc.
It might help someone along the line.
AAA
4-WAY MANUAL SEAT ADJUSTER
AG1
ADJUSTER, FRT ST, POWER, 6 WAY DRIVER, SPLIT BENCH
AK5
RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
AQ9
SEAT, FRT PASS A DRIV, RECL
AU0
LOCK CONTROL, REMOTE ENTRY – KEYLESS ENTRY (DOMESTIC)
AU3
LOCK CONTROL, SIDE DR, ELEC
A31
WINDOW, POWER OPERATED, ALL DOORS
CC1
ROOF HATCH, REMOVABLE PANELS, GLASS
DE4
SUNSHADE, REMOVEABLE HATCH ROOF
DG7
MIRROR O/S, LH & RH, REM CONT, ELEC, PAINTED
DL5
DECAL, ROADSIDE SERVICE INFORMATION
FE2
SUSPENSION SYSTEM, RIDE HANDLING
FE9
CERTIFICATION, EMISSION, FEDERAL
GU5
AXLE REAR, 3.23 RATIO
G80
AXLE POSITRACTION, LIMITED SLIP
IL2
TRIM-INTERIOR DESIGN
J65
BRAKE SYSTEM, PWR, FRT & RR DISC
RPO Code K43 Not Found In Database
LS1
5.7L GEN III V8 ENGINE
MX0
MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
M30
TRANSMISSION, AUTO 4 SPD, HMD, 4L60E, ELECTRONIC
NF2
EMISSION SYSTEM, FEDERAL, TIER 1
NP5
STEERING WHEEL, LEATHER WRAPPED
NW9
TRACTION CONTROL - ELECTRONIC
P05
WHEEL, CHROME, VAR 1
QLC
TIRE ALL, P245/50ZR16/N BL R/PE ST TL HW4
RPO Code R7X Not Found In Database
RPO Code R9P Not Found In Database
RPO Code STE Not Found In Database
T43
SPOILER, RR
T78
HEADLAMP CONTROL - DELETE
UA6
THEFT DETERENT SYS
UB3
CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
UK3
ELECTRONIC SYSTEM, ACCESSORY CONT
U75
ANTENNA, POWER, RADIO
RPO Code VM3 Not Found In Database
V73
ANTENNA, FIXED
WS9
MODEL CONVERSION, FORMULA
RPO Code W55 Not Found In Database
Y82
MERCHANDISED PKG, FORMULA
1SA
OPTION PACKAGE 01
14I
INTERIOR TRIM, LT GRAY (I) (92)
142
TRIM COMBINATION, LEATHER, LT GRAY (2) (92)
41U
PRIMARY COLOR, EXTERIOR, BLACK
RPO Code 6ZM Not Found In Database
RPO Code 7ZM Not Found In Database
RPO Code 8TJ Not Found In Database
Works great! Thanks
AG1
AK5
AQ9
AU0
AU3
A31
CC1
DE4
DG7
DL5
FE2
FE9
GU5
G80
IL2
J65
LS1
MX0
M30
NF2
NP5
NW9
P05
QLC
T43
SPOILER, RR
T78
UA6
THEFT DETERENT SYS
UB3
UK3
U75
V73
ANTENNA, FIXED
WS9
Y82
1SA
OPTION PACKAGE 01
14I
142
41U
Works great! Thanks
Try www.camarosource.com. I got all my RPO codes from them. A friend of mine works at a chevy dealer and pulled up all the codes from the GM inquiry system which was very detailed, a little better than the above site.
Nice database!
Anyone know what FE4, Z06 Suspension System, consisted of?
AG1
AK5
AR9
SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU0
AU3
A31
A90
LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
RPO Code bbs Not Found In Database
B84
ORNAMENTATION, EXTR MLDG, BODY SIDE
RPO Code cae Not Found In Database
CC1
C49
DEFOGGER, RR WINDOW, ELECTRIC
C60
HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DE4
DG7
DL5
fe4
SUSPENSION SYSTEM, Z06
FE9
GU6
AXLE REAR, 3.42 RATIO
G80
ip2
Seat, Leather Sport Front Bucket, Driver & Passenger, Reclining
J65
K34
CRUISE CONTROL, AUT0MATIC, ELECTRONIC
LS1
MM6
TRANSMISSION, MAN 6 SPD, BORG WARNER
MN6
MERCHANDISED TRANS, MAN 6 SPD PROVISIONS
RPO Code nf7 Not Found In Database
NP5
NW9
N73
WHEEL, CUSTOM SPORT, VAR 4
pbt
IDENTIFICATION TEMPORARY WHL & TIRE FOR UPFITTER DELIVE
RPO Code qfk Not Found In Database
RPO Code r97 Not Found In Database
SLM
STOCK ORDER, PROCESSING CODE
ste
PLANT CODE - ST. THERESE, PQ, GM OF CANADA
RPO Code ts9 Not Found In Database
T82
HEADLAMPS, AUTO ON-OFF CONT
T96
FOG LAMPS - FRONT
UA6
THEFT DETERENT SYS
UB3
UK3
UL0
RADIO – AM/FM STEREO, CASS. (EUROPE COMPLIANT)
uz7
Speaker System, 8 Quat Frt Dr Mtd Dual RR Hatch Amplifier
U73
ANTENNA, FIXED, RADIO
VK3
LICENSE PLATE, FRT MOUNTING PKG
vm3
INFORMATION CONSUMER LABEL, BUMPER IMPACT STANDARDS
V12
COOLING SYSTEM, POWER STEERING, FLUID
V73
ANTENNA, FIXED
wu8
SS PERFORMANCE/APPEARANCE PKG
RPO Code y2y Not Found In Database
Z28
MERCHANDISED PKG, SPECIAL PERFORMANCE
1AY
STOCK ORDERS PROCESSING OPTION (DEALER ORDERED CAR)
1SD
OPTION PACKAGE 04
1sz
OPTION GROUP SAVINGS
19I
INTERIOR TRIM, BLACK (I) (91)
RPO Code 6bs Not Found In Database
RPO Code 7bs Not Found In Database
8TJ
LEFT REAR SPRING P/N 22077421 (19.9 N/MM, 114 LBS/IN)
81Q
MOLDING COLOR, BRIGHT RED (91)
81U
PRIMARY COLOR, EXTERIOR, BRIGHT RED (91)
9tj
RIGHT REAR SPRING P/N 22077421 (19.9 N/MM, 114 LBS/IN)
ttt
AG1
AK5
AR9
AU0
AU3
A31
A90
B84
CC1
C49
C60
DE4
DG7
DL5
fe4
FE9
GU6
G80
ip2
J65
K34
LS1
MM6
MN6
NP5
NW9
N73
pbt
SLM
ste
T82
T96
FOG LAMPS - FRONT
UA6
THEFT DETERENT SYS
UB3
UK3
UL0
uz7
U73
VK3
vm3
V12
V73
ANTENNA, FIXED
wu8
Z28
1AY
1SD
OPTION PACKAGE 04
1sz
19I
8TJ
81Q
81U
9tj
ttt
I honestly wasnt aware of how many RPO codes exist in the database. I have a ton that even a google search wont reveal, go figure. Thanks for the comments guys.
Good luck finding a complete listing. Every single list I have found, has pieces other dont, a deal would have the full list, but I dont know how youd go about getting it.
TTT... My database has been getting a lot more traffic, and ive started logging missed codes. I fanyone has a hook up and can get me some of these codes id appreciate it. id give credit where its due, its just a lot of fellow fbody brothers are leaving with out getting all there codes
I've got a couple lists stored on my computer - one's a word pad listing that's pretty comprehensive, the other is a PDF file that even lists all the codes for the trucks too. I've used them before to find the "hard to find" codes for people in the past - if you think they'll help I'll email them to you.
