0-2 sensor extensions needed for longtubes???
Long tubes are going in soon, anyone who has installed a set of longtubes no matter what brand for a 00 SS LS1, have you needed 0-2 sensor extensions??? Just asking before so that I don't have any issues or problems on Tuesday and if so, I can order them now.
now trying to be offensive here but it sound like ur gonna put long tubes on with ur loud mouth? ive heard that equals a lot of rasp and doesnt sound that good. i just wanted to put that out there so u had an idea hope it helps
Originally Posted by anthonyz281999
i was under the impresion that u could just buy 02 sims and they go over ur 02 sensors and trick them into thinking there still working
'Bird Director
Yes, you'll need the extensions for the two remaining 02 sensors that get relocated to the collector-area of the long-tube headers. The long-tubes and Loud Mouth together do create a lot of rasp. You might consider doing the Dynomouth mod. That's what I ended up doing. Just do a search on the subject as there are lots of threads on it.
Bringing back from the dead what length extension did you guys go with, and I am keeping my cats so I need extensions for the rear o2's as well? Just wanted to clarify so I can buy and get the headers on.
Depending on what catted Y you use I guess, if it even has the holes for the rear 02's. my TSP catted Y didnt have bungs for the rear 02's (no biggie) b/c I had already bought sims for the rear ones anyway.
To use your stock 02's...you need 2 extensions for both front 02's. The driver side is far from making it but the passenger side comes fairly close. I would say buy one 24" and one 12" and you would be good. My hookers came with 2 24" extensions and they were way long on the pass. side.
Good luck on your install.
Listen to what jimmyblue said above. Get new Vette rear o2s (Bosch 13111) and use these up front...they have enough wire that you don't need extensions, and you'll have peace of mind knowing you have new o2s. Get the rear o2s tuned out, or you'll have a SES light all the time with the QTP cats. You won't need extensions on the rears, but it won't matter anyway after they're tuned out.
1 Post
EXACTLY. Look in my Signature. I have had all those F-bodies and this is what i have done and never had a problem. My current SS has these O2s and the rears have been tuned out
Here is what I do..
I re-pin the back O2 Sensor Connectors to be the fronts in the PCM, and plug them in there when I install them in the Headers. Yea it's a little work, but it saves money and it's using what is already there.
I have done this on a few cars. I have my Harness built to where the O2 Connectors come out ontop of the T56, works perfectly.
I kept on melting Extentions, that is why I did it this way.
