Couple of maintenance questions ?
1)
I was wondering if it was ok to use PRESTONE coolant intead of dex-cool. On the bottle it says it is GM dex-cool approved ?
2)
What should I used to grease the rubber molding on the car by the windows ? Is wd-40 ok ?
3)
what brake fluid and cylinder fluid do you guys use
thanks in advance
2)
3)
thanks in advance
Originally Posted by TheBlurLS1
1) why wouldnt you want to use dex-cool? EVERYBODY runs it, and they say its kosher
2) i would use armor-all or somthing like that, not WD-40.
3) dot 3
3) dot 3
thanks,
what about m6 cylinder fluid ?
the clutch master cylinder fluid?
it's dot 3 brake fluid as well
brake fluid = hydraulic fluid = clutch master fluid , the DOT rating is how much heat it can take before it cooks itself.
Good to know man. Thanks
Yep. Dielectric grease for the rubber moldings. Also make sure you put some in the runner up front (black triangle piece) It will really help with the speed of the windows and help you window motors last.
I just use spray silicone or the greasy rag I used to detail my dash about every 2-3 washes(when I wax/detail). dielectric is good lube cause youd only have to use it 1-2 times a year or so, but is messy and takes a little more attention to detail than I'd like to spend.
if it's orange it's dex-cool, it's a type of coolant not a certain brand.
Originally Posted by locosteelersfan
I've never put it on the inside of molding. What's your technique?
Doensn't it get all over the glass?
What do you recommend to clean the engine that will not mess it up and it looks like it has been done professionally? What about a blue stain in the leather seats that mcguires leather cleaner will not take out?
Do you wipe it off? Your saying that it doesn't swear as the window goes
up and down, seems like it'd be all over.
