Help
Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!
After A Few Minutes Of Driving The Rpm's Skip And It Lags On Catching Speed IT IS A 98 Z28 6 SPEED MM6 MN6 WHEN THE RPM SKIPS 4 EXAMPLE IT IS AT 2.5 AND I PUSH THE GAS AND IT DOES NOT MOVE AND IT WILL JUMP TO LETS SAY 3.5 AND LETS SAY IM IN FIFTH GEAR AND PUSH THE GAS IT REVS UP BUT IT WONT ADVANCE SPEED FOR A SEC OR 2 AND THEN IT WOULD SPEED UP JUST A BIT
could you describe you experience a bit more.. Wat exactly do you mean by "lag" and skip? The rpm started to jump around,fall, go up? Or it is now sluggish?
also some more info would help as well. Mileage, year, mods (if more than on your sig), that kind of stuff.
help us out, we should be able to help you
good luck!
good luck!
