Stock gear ratio in a 98 z28
Old 05-02-2005, 06:50 PM
Intermision's Avatar
Default Stock gear ratio in a 98 z28
What are the stock gears in a 1998 z28?
Old 05-02-2005, 07:06 PM
WhiteRhino's Avatar
Is it an auto or stick.Sticks have 3:42's and auto's had 3:23's or 2:73's.If the sticker is still on the door you can see witch gears you have.It'll be a gu code.(gu4,gu5 a letter number like that).
Old 05-02-2005, 08:39 PM
blkZ28spt's Avatar
If it's GU5 you have 3.23's. If it's the other one you have 2.73's. (for A4)
Old 05-03-2005, 12:14 AM
RIP April 14, 2008
Diolar Magnum's Avatar
Location: the land where cars repeatedly hit my bumper when I'm in the store...
98 Z28 A4 checking in with 2.73's
Brad
Old 05-03-2005, 02:39 AM
Stone0fFire's Avatar
GU2 =
downshifting to 1st @ 40mph & leaving 2nd @ 104mph
gas mileage is good too, doing 80mph @ 2,000rpm
Old 05-03-2005, 11:46 AM
blkZ28spt's Avatar
GU2: Talk about having a dead spot at the bottom of second gear!
Glad my car came with the $400 "performance axle" from the factory.
Old 05-04-2005, 12:29 AM
'Trust''s Avatar
Performance Axle, what code is that?
Old 05-04-2005, 12:32 AM
natronathon's Avatar
GU5, got it, and I LOVE IT!!!! if you cruise at 60 mph right around 2000 rpms give or take 50 rpms or so, you have the 3:23's. If you have incredibly low rpms at this speed, then you have 2:73's. Im glad personally that I have 3:73's! Came with an aluminum drive shaft as well!!
Old 05-04-2005, 12:44 AM
That's what she said...
TheBlurLS1's Avatar
when i bought my 6-speed car, the speedometer was off (showed 70 when going about 77). come to find out, like 8 months later, the "rear end work" that was done to my car before i bought it included having the 3.42 ring and pinion replaced with a ******* 3.08
this must also mean that the carrier was replaced with a 2 series. the gear install was so incredibly crappy, that the ring gear had actuall worn a groove into the cover. i still managed to blow up 3.08 gears on 245/50/r16 rubber NEVER once going to the track
thaaaaaaats why my car always hooked up so well
after switching to a moser 12 bolt w/ 4.11's, 2nd gear pulls like first used to
Old 05-04-2005, 10:13 AM
'Trust''s Avatar
Got GU5 too, nice! and the driveshaft
Quick Reply: Stock gear ratio in a 98 z28
