howling noise between 25-60 MPH
Old 05-07-2005, 09:40 PM
LiquidFire350's Avatar
Default howling noise between 25-60 MPH
ok, heres probly the most bizzare thing youve ever heard, maybe not, who cares, anyways
when im just coasting at a constand speed, between 25-60, i hear a howling noise, but only when my foot is on the gas, if i take my foot off the gas it takes a second but the noise goes away completely, but this only happens at a constand speed with the gas pedal between 1 - 25% throttle, any more than that and the noise goes away but the car accellerates and then im speeding, the noise gets louder as i go faster, most noticable between 45-60 mph
just in case, mods are: 3.23s, !EGR, !AIR, LM, lid and bellows, 160* temp, throttle body bypass
willing to try all suggestions, so any help is appreceated
Old 05-07-2005, 09:43 PM
That's what she said...
TheBlurLS1's Avatar
sounds like ring and pinion problems to me! mine used to do the same, especially right before it blew
my 12 bolt whines a very very SLIGHT amount between 50 and 30 when i take my foot off the gas.
Old 05-07-2005, 09:50 PM
i was starting to think it is the ring and pinion, i just put in the 3.23s and they are used, i thought ring gear noise only happened when your off the gas tho, dam, hope it dont go out, if it does, im throwing in 3.73s
ps. Blur, your old sig pic was better
Old 05-07-2005, 09:53 PM
just thought of this, why would it only make noise at low throttle postitions, for example at half throttle, there is no noise
Old 05-08-2005, 03:29 AM
TheBlurLS1's Avatar
i made the one that's in there now, slammed-am made the last one. i got tired of looking at it lol
Old 05-08-2005, 12:37 PM
FastazfukWS6's Avatar
i have the same problem at the same speeds and i have asked my friends but they have no idea. if it is the ring and pinion witch one should i put it for a mod? it makes the ride uncomfertable when cruising on the highway and it is a very anoying loud sound. i really need help on this guys so please any suggestions would be great on how i can take that howling noise out, i freaking hate it. if anything e-mail me at Wolfpac723@aol.com or just write it here and i will read it. i really need this guys i really apreciate it thanx.
Old 05-08-2005, 02:43 PM
Azrael's Avatar
Yeah it sounds like the backlash is off on the R&P... I am still not sold on putting gears in the 10 bolt, IMHO it would be better in the long run to save for a 12 bolt...
If you do open it up look for the pattern of wear on the ring gear teeth...
Old 05-08-2005, 03:28 PM
i get the noise as soon as i press the gas even if it is just a little bit. i have to get rid of the noise i hate it
Old 05-08-2005, 05:29 PM
same here, but only a little bit, WOT there is no noise..... well you really cant hear much over a Loudmouth at WOT
Old 05-08-2005, 08:32 PM
99FormulaM6's Avatar
mine does it too. cant really hear with the TD's...but its def there. mine started after i made a top speed run and got to like ~165. when i got back to speed, it was doing it. but hey, what can you do? when it blows, hello 9 inch
Old 05-09-2005, 08:08 AM
Originally Posted by 99FormulaM6
mine does it too. cant really hear with the TD's...but its def there. mine started after i made a top speed run and got to like ~165. when i got back to speed, it was doing it. what hey, what can you do? when it blows, hello 9 inch
yea, ive decided to let it go and if it does blow, Strange 12 bolt with 3.73s, id better start saving up now
Quick Reply: howling noise between 25-60 MPH
