Request Part Numbers
Old 04-21-2006, 08:14 PM
  #221
speedfrk77's Avatar
Default Monsoon Part #
I need the part #'s for all the speakers for a 99 camaro z28 Monsoon stereo.
Can you break them down in left and rights?
Old 04-23-2006, 08:44 PM
  #222
TEX02SS's Avatar
can i get the part # for the 12 disk changer for 02 monsoon stereo in camaro. Thanks!!
Old 04-23-2006, 11:36 PM
  #223
LSWannabe's Avatar
Need PN for our PS pump assembly.
Thanks.
Old 04-24-2006, 09:01 AM
  #224
WhiteRhino's Avatar
Originally Posted by MM98
98-02's didn't come with those that I'm aware of & I don't show any listed in my catalog either... 93-96's did have front ones though & the part# is 10248387.
Mike
I forgot I asked. Thanks for the help. Shouldnt the pre 98 years still have the same console. I dont know if they changed them or not. I dont think they did but I cant remember what my 95 TA looked like compared to my 98 TA.
It was for the rubber cup holder inserts. I know my 97 Z28 had the rubber cup things in the single front and in the rear double holder.
Old 04-24-2006, 03:03 PM
  #225
spee's Avatar
Is there an LT1 stock clutch replacement kit like ones for LS1/6?
Old 04-24-2006, 04:59 PM
  #226
DataCom's Avatar
Default 3 hole upper door hinge
Hello,
I have a 94 formula and am having a problem with the LH upper door hinge Part #. When I ordered the parts from the dealer I ended up with a 2 hole hinge. they said their parts cataloge listed 16630875 as the upper hinge for 93-02.
According to the list below it should be 95-02 and the 3 hole should be 16626519. However nothing showed up in their cataloge using the part # 16626519.
At this point I am at a loss of where to get a new 3 hole upper hinge with the plate or the part numbers. Also when I searched/googled for 16626519 nothing showed up. The part numbers below are from this site. Is 16626519 the wrong number?
https://ls1tech.com/forums/general-maintenance-repairs/336981-lt1-lt4-ls1-ls6-f-body-part-numbers.html
front side door lower hinge (93-02), RH = 16628998
front side door lower hinge (93-02), LH = 16631043
front side door upper hinge (93-02), RH = 16630874
front side door upper hinge (95-02), LH = 16630875
front side door upper hinge (93-94), LH = 16626519
DataCom
Old 04-24-2006, 11:24 PM
  #227
MM98's Avatar
Originally Posted by DataCom
Hello,
https://ls1tech.com/forums/showthread.php?t=336981
DataCom
Here you go man:
Upper LH hinge, part#16630875 & you must also use plate #10268961
Upper RH hinge, part#16630874 & you must also use plate #10268960
Mike
Old 04-24-2006, 11:46 PM
  #228
ACW
ACW's Avatar
Here you go man:
Mike
So the 95-02 upper LH hinge is now also being used for 93-94?
  #229
jlarsen's Avatar
Need the number for the front defroster vent cover that sits just on the A-pillar molding, the little circle one a little bigger than a quarter
Old 04-25-2006, 01:14 PM
  #230
MM98's Avatar
Correct, along with the two plates that I listed are needed for the swap on the 93-94's.
Old 04-25-2006, 06:49 PM
  #231
MM98's Avatar
LH side: part#10268190
RH side: part#10268189
Old 04-26-2006, 12:31 AM
  #232
ACW
ACW's Avatar
Thanks.
LT1 power steering pump kit (93-97) = 26040864
LS1 power steering pump kit (98-02) = 26068936
Old 04-26-2006, 01:04 AM
  #233
ACW
ACW's Avatar
12-disc CD changer (97-98) = discontinued, use 99-02 (formerly 16199553)
12-disc CD changer (99-02) = 25678544
12-disc CD changer cartridge (97-02) (Pioneer #JDT-1212) = 25678545
12-disc CD changer kit (changer and cartridge) = 12371528
wiring harness for 12-disc CD changer (97-02) = 12344003
Old 04-26-2006, 01:45 AM
  #234
ACW
ACW's Avatar
Camaro door front speakers (97-02 - UZ7 premium audio), RH = 9361859
Camaro door front speakers (97-02 - UZ7 premium audio), LH = 9361869
Camaro rear quarter trim panel speaker (97-02 - UZ7 premium audio) = 16217731 (use same for LH and RH)
Camaro rear sail panel (B-pillar) speaker (97-02 - UZ7 premium audio) = ? (formerly 16235651) (use same for LH and RH)
Old 04-26-2006, 01:46 AM
  #235
ACW
ACW's Avatar
If there is a kit package like those, I'm not seeing it.
MM98, any idea on this?
Old 04-26-2006, 01:52 AM
  #236
ACW
ACW's Avatar
Originally Posted by BackinBlack02SS
Part number for the small plastic wire clip, or loom, that the abs wire runs through. It inserts into the front lower control arm on both the driver and passenger side. Basically looks like 2 circles with a fastner on the end if that helps.
Think I found the wiring harness you're talking about, but I'm not having much luck on that fastener. It might only come together with the wiring harness.
Old 04-26-2006, 02:29 AM
  #237
ACW
ACW's Avatar
Originally Posted by black99z28
I was wondering if you could find the part number(s) for the rear compartment trim peice that the speakers go in on both sides.
jack-hole that owned the car before me cut the holes to fix 6x9's in there.
Camaro rear quarter interior trim panel:
(97-99 with UZ7 premium audio), neutral, RH = 16675643
(97-99 with UZ7 premium audio), neutral, LH = 16675644
(97-99 with UZ7 premium audio), gray, RH = 16633448
(97-99 with UZ7 premium audio), gray, LH = 16633453
Old 04-26-2006, 10:14 PM
  #238
That's MISTER MODERATOR
Paul Bell's Avatar
1994 Firebird part numbers:
Tail/stop lamp sockets (pigtails), for the 1157 lamps.
and
The body plug in the rear floor pan.
Thanks!
Old 04-27-2006, 09:02 AM
  #239
MrEddie's Avatar
2000 Z28 M6
2 heater hoses going from engine to heater core
throttle body coolant lines
Thanks!
Old 04-27-2006, 12:15 PM
  #240
SleeperSS's Avatar
Does anyone know the part # for the hose that goes from the the radiator to the powersteering cooler. Its the inlet hose.
Quick Reply: Request Part Numbers
