Request Part Numbers
Old 04-27-2006, 07:11 PM
  #241
MM98's Avatar
1994 Firebird part numbers:
Tail/stop lamp sockets (pigtails), for the 1157 lamps.
and
The body plug in the rear floor pan.
Socket: part#12141493
Floorpan plug: part#10208798
2000 Z28 M6
2 heater hoses going from engine to heater core
throttle body coolant lines
Thanks!
Heater core hose assm: part#10415020(includes both hoses)
TB coolant lines: part#12556452 & 12562165
Does anyone know the part # for the hose that goes from the the radiator to the powersteering cooler. Its the inlet hose.
Hose from cooler to radiator: part#10413567
Mike
Old 04-30-2006, 11:04 AM
  #242
fast377's Avatar
I could use a few part numbers please...all for 99 M6 Fbody
bellhousing to gearbox bolts
bellhousing to block bolts
rear oil pan bolts (ones that go into rear main seal cover)
dipstick and tube (I saw the number for 98 but don't know if its different)
slave cylinder mount bolts
torque arm mount and bracket
fuel tank filler neck and tube assembly
Thanks
Old 05-01-2006, 09:23 PM
  #243
MM98's Avatar
Thanks
bellhousing to gearbox bolts: #14050422
bellhousing to block bolts: #22649722
rear oil pan bolts: #12554990.
dipstick and tube: #12551581(indicator) & #12551577(tube).
slave cylinder mount bolts: #11516424.
torque arm mount and bracket: #10252374(inner) & #10252375(outer).
fuel tank filler neck and tube assembly: #10409866(hose) & #10409867(pipe).
Old 05-01-2006, 11:13 PM
  #244
fast377's Avatar
You're the man!! THANK YOU!!
Old 05-03-2006, 09:04 PM
  #245
RpSS4844's Avatar
is Part number 16837696 described as "Camaro front seat back cover....ebony" the covers for the front seats as well as the rears? What I am trying to do is recover some cloth seats from a 97 Z28 to be the original ebony leather that came in my car (2001 CamaroSS). I was a dumbass and sold them and now wish I wouldnt have. What other part numbers would I need to complete this task?
***Also big thanks putting that page together with all the part numbers***
Old 05-03-2006, 09:55 PM
  #246
MM98's Avatar
Here you go man:
FRT LH & RH ebony seat back cover(leather): #16837696
FRT LH & RH ebony seat cushion cover(leather): #16837698
Rear LH & RH ebony seat cushion cover(leather): #16840531
Rear ebony seat back cover(leather): #16840538
Mike
Old 05-03-2006, 10:23 PM
  #247
RpSS4844's Avatar
Originally Posted by MM98
Here you go man:
Mike
Thanks for the quick reply!! I looked all these up at GMparts direct, and it is almost $1000 for all the covers Does anyone know where to find this stuff more reasonable like $500-$600. That is extremely too much to invest in this project, that doesnt include the stuff i will need to secure them to the seat.
Old 05-04-2006, 09:38 PM
  #248
Blue2KTA's Avatar
2000 Trans Am....Drivers side tail light wire harness part number please.
Thanks
Old 05-06-2006, 03:17 PM
  #249
jimmypop13's Avatar
I need the part number for the exhaust bracket that bolts to the passenger side of the car. It has rubber on the inside of it. The rubber in mine is all worn out so the exhaust rattles on the axle. Every dealership I've gone to doesn't have it in stock but they all quoted me at around $20 so I don't think it's this part number listed earlier:10407350 since list on it is only $13. Thanks!
Old 05-06-2006, 03:25 PM
  #250
jimmypop13's Avatar
I just found it! 10275709
Old 05-06-2006, 03:44 PM
  #251
9silverbird8's Avatar
You just need the rubber piece? $10 and its yours
Old 05-06-2006, 04:55 PM
  #252
lovin myls1's Avatar
I'm new to threads...is this how to best get part numbers?Cause I just had a GM dealer look them up,said he had to order them and charged me 45-50 % over list!!!I found this out by running the #'s on GM Direct.Cancelled the order!!
Old 05-06-2006, 05:34 PM
  #253
ACW
ACW's Avatar
Yeah, it's usually better to try to find out the numbers ahead of time so you can shop around and know if someone's overcharging
Old 05-06-2006, 06:54 PM
  #254
And there is usually someone knowledgeable on LS1tech that is willing to provide the number? Man,thats great!! Thanks
Old 05-06-2006, 07:24 PM
  #255
ACW
ACW's Avatar
MM98 and I try to
Old 05-06-2006, 07:45 PM
  #256
ACW
ACW's Avatar
Thanks
Firebird taillamp wiring harness (93-02) = 12177554
Old 05-06-2006, 08:13 PM
  #257
ACW
ACW's Avatar
Glad you like it
I didn't have all of the portions of that set of seat covers listed yet, only the back-part of the front seat. Will add those other ones now.
Don't think you'll be able to get them any cheaper new... best bet is to check with salvage yards, or check the ls1tech classifieds for someone parting out.
Old 05-06-2006, 08:24 PM
  #258
Blue2KTA's Avatar
Thanks...Found out today its not the harness but its the drivers side tail light assembly Do you have the part # for that ?
Thanks
Old 05-06-2006, 08:30 PM
  #259
ACW
ACW's Avatar
Thanks
Sure do
Firebird taillamp assembly (98-02) (honeycomb), RH = 10431948 (formerly 10439148)
Firebird taillamp assembly (98-02) (honeycomb), LH = 10431949 (formerly 10439149)
Old 05-06-2006, 11:17 PM
  #260
96silverram's Avatar
What an incredible resource. I just found two parts in about two minutes !
Thanks
Quick Reply: Request Part Numbers
