Request Part Numbers
Old 10-26-2005, 10:30 PM
  #41
Beast's Avatar
Doesn't ARP offer those bolts? Anyone know if ARP offers intake and exhaust bolts for the LS1?
Old 10-26-2005, 11:30 PM
  #42
TransAmGT's Avatar
I need the part number for the Skip Shift Solenoid....i saw the one for the seal but i need the actual solenoid!
Old 10-27-2005, 06:59 PM
  #43
ACW
ACW's Avatar
M6 skip shift solenoid (94-02) = 12523292
Old 10-27-2005, 07:01 PM
  #44
ACW
ACW's Avatar
Yep, they do. http://www.sdpc2000.com/cart.asp?act...&manufac_id=18
Old 11-02-2005, 03:31 PM
  #45
NaughtyGirlTA's Avatar
How about 3 more part numbers:
6.0 Truck Exhaust Manifold Gaskets (go against the heads)? Also, are they sold individual or in pairs?
And 6.0 Truck Exhaust Manifold Collector gaskets?
1998 F-Body LS1 Temperature Sensor (mounts in DS head, 3 pin style)?
Thanks again!!!!!
Old 11-02-2005, 04:11 PM
  #46
Luna's Avatar
I need the part number for the little round thing on a firebird that covers the joint on the passenger cup holder. Sorry if you dont know what I'm talking about ....
Old 11-02-2005, 11:18 PM
  #47
TheSilverOne's Avatar
part number for an A4 shifter handle for a 02 camaro
Old 11-03-2005, 02:32 AM
  #48
ACW
ACW's Avatar
Looks like the 6.0L uses the same ones as the 5.3L and 4.8L. Think they're sold individually.
exhaust manifold gasket = 12558573
These seem to be the gaskets between the manifolds and the cats, but I haven't found the number for these on the 6.0L (and so don't know if these are also the same or not).
Here they are on the 5.3L (might be old numbers, don't know what the new ones are if so, but a dealership should be able to cross-reference):
LS1 catalytic converter gasket (between cat and manifold) (98-02), LH = 12555806
LS1 catalytic converter gasket (between cat and manifold) (98-02), RH = 88891747
Thanks again!!!!!
That one, I just confirmed yesterday
LS1 coolant temperature sensor (98) (3-wire sensor: 2 for PCM, 1 for gauge) = 12551708
Old 11-03-2005, 02:52 AM
  #49
ACW
ACW's Avatar
front cup holder trim cover (round) (97-99 Firebird, 97 Camaro) = 10288510
front cup holder trim cover (round) (00-02 Firebird) = 10421365
front cup holder trim cover (round) (98-02 Camaro) = 10281310
front cup holder trim cover (push-in for 12mm square hole) (00-02 Camaro) = 17988488
Old 11-03-2005, 03:03 AM
  #50
ACW
ACW's Avatar
A4 control lever (shifter) **** (93-99 Camaro with RPO NP5) = 10079809
A4 control lever (shifter) **** (00-02 Camaro with RPO NP5) = 12563173
A4 control lever (shifter) **** (93-99 Camaro with RPO NK3) = 10111639
A4 control lever (shifter) **** (00 Camaro with RPO NK3) = 10163833
A4 control lever (shifter) **** (01-02 Camaro with RPO NK3) = 22680651
A4 control lever (shifter) handle (95-99 Firebird with RPO N36) = 12551597
A4 control lever (shifter) handle (00-02 Firebird with RPO N36) = 12563171
A4 control lever (shifter) handle (95-02 Firebird with RPO NP5) = 12563172
NK3 = Steering Wheel, Sport, Soft Rim, Simulated Leather
NP5 = Steering Wheel, Leather Wrapped
N36 = Steering Wheel, 4 Spokes, Sport
Old 11-03-2005, 06:06 PM
  #51
2000blackta's Avatar
How about gaskets for both the right and left valve covers? I couldn't find the part number for a new oil filler neck and cap either?
Old 11-04-2005, 01:08 AM
  #52
ACW
ACW's Avatar
LS1 valve cover gasket (98) = 12556429
LS1 valve cover gasket (99-02) = 12560696
both LH and RH use the same one
LS1 oil filler tube (with o-ring seal) = 12559505
LS1 standard oil filler cap = 24504599
LS1 oil filler cap with Mobil 1 logo = 12555685
Old 11-07-2005, 10:11 AM
  #53
Luna's Avatar
thanx ACW ur da man!
Old 11-23-2005, 10:21 AM
  #54
mc01ta's Avatar
Need an ebony driver side interior door panel part # for a 2001 trans am. Mine is cracked. Can you PM me this info too please?
Old 11-23-2005, 11:43 AM
  #55
WhiteRhino's Avatar
Do you know if there is a new part number for a T/A rear bumper cover?The one that is listed (Trans Am rear bumper fascia (cover) (93-02) = 10201178) doesnt come up as a valid part number.I've tried to find a new number and cannot locate one.
Thanks
Old 11-23-2005, 12:02 PM
  #56
kenp's Avatar
Rear bumper try 12335526 & 12335511. Make certain prior to ordering.
Old 11-23-2005, 12:41 PM
  #57
WhiteRhino's Avatar
Thats whats messing me up.Gm parts direct has a group of numbers.
Under T/A Under Formula
10242397 10242406
10201178 12335526
12335511 12335524
10418941
So I guess I should quit being lazy and call the dealership to get the right number.Although I'm sure those are front and rear numbers mixed.I wish Gm parts direct had more info for the numbers without having to click on all of them.Even then sometimes the description isn't clear.
Old 11-26-2005, 11:54 PM
  #58
ACW
ACW's Avatar
There's several possibilities for the interior door panel. Cloth or leather? Which entertainment package RPO (affects speaker placement) do you have -- W53, W54, W55, X10, or X20?
Old 11-26-2005, 11:55 PM
  #59
ACW
ACW's Avatar
Originally Posted by WhiteRhino
Do you know if there is a new part number for a T/A rear bumper cover? ... So I guess I should quit being lazy and call the dealership to get the right number.
Just call a dealership and ask what the updated part number is for 10201178 Let us know what you find out.
GMPD's catalog has a number of issues
Old 12-09-2005, 06:42 PM
  #60
racer7088's Avatar
Thumbs up
LT1 oil galley internal 12mm ball bearing GM plug?
Can you find the number for this? No one else seems to be able to? I had it but we lost it. Its the internal oil galley plug that diverts oil to the oil filter and is a 12mm stanless steel ball bearing from GM. Thanks very much ahead of time!
Quick Reply: Request Part Numbers
