Request Part Numbers
Old 01-25-2012, 12:59 PM
  #721
STG1BUICK's Avatar
Default part number request
I've searched the forums and haven't found part numbers
for a 1999 WS-6 with traction control:
rear axle reluctor wheel
and for ebony interior- right kick panel
Thanks, David
Old 02-19-2012, 02:41 AM
  #722
sjsingle1's Avatar
need the 2 rubber bumpers that keep the gas cover from hitting the trim ring
Old 02-21-2012, 05:26 PM
  #723
airpower326's Avatar
Default ws6 front bumper cover brackets to lh and rh fender
I'm sorry to ask but I looked through the list and not knowing the
name of these brackets I had to ask. Mine is an 02 ws6, I need the brackets
that piece together the bumper cover to the fenders. They look like little black brackets that have an L shape to them. If you need photo's I'll be happy to send some. Let me know
Thanks
Joe
Old 02-29-2012, 11:19 AM
  #724
DesertGator's Avatar
I've been looking for a while. I need the part number for the drivers side seat back (the actual seat back) for a 1999 Trans AM. This thing is beyond reupholstering.
Thanks in advance!
Old 03-07-2012, 04:36 PM
  #725
White.Lightning's Avatar
I've searched for an hour or so....
Rear hatch glass, outside trim/molding, black....around the whole edge of the rear hatch glass
Mine is cracked and falling off. Also, do I need to install this with adhesive?
Old 05-11-2012, 03:24 PM
  #726
teda's Avatar
Do up know the part number for the plate the traction control switch fits into, the back piece broke off inside and I can't get it to stay. Thanks in advance. ooohh and also the butterfly wingnuts that attach the tail light assembly. I drive an 02 trans am.
Old 05-11-2012, 08:37 PM
  #727
Ferocity02's Avatar
Looking for the right and left flywheel inspection covers for a GTO. They are the black plastic pieces that bolt to the side of the block and let you see the the flywheel when removed. Thanks!
Old 07-11-2012, 03:32 AM
  #728
badger89's Avatar
What about the four wire connector mounted on top of the fuel pump assembly outside the tank next to the pressure sensor? Wire broke off at the base and I can't find it to save my life
Old 08-20-2012, 09:54 AM
  #729
Thomas Aquinas's Avatar
I'm trying to install a stock grille on my camaro so I can put a front plate on it. I have the 3 nuts for top of the grille.
But I need the part number for the bottom 3 push on clips for the grille.
Thanks.
Old 09-18-2012, 02:57 PM
  #730
buddha845's Avatar
Rear side markers? A few sites have them but I am not able to find a part # for these things anywhere.
Old 01-07-2013, 09:18 AM
  #731
LS-ONE_DAY's Avatar
Looking for part number for driver side A-Pillar for 1999 Pontiac Firebird Formula (the graphite gray interior, not the darker ebony interior)
Old 01-07-2013, 10:24 AM
  #732
Bad Karma CZJ's Avatar
Whats the p/n of the tall oil filler neck?
Thanks
EDIT... found it... 12574386
Old 03-05-2013, 10:23 PM
  #733
desormeaux05's Avatar
Does anyone know the part number for stock LS1 rocker arms? Not the rocker arm bolts the entire rocker arm.
Old 03-11-2013, 02:26 AM
  #734
cnw8891's Avatar
I'm looking for the rubber trim/seal/weatherstripping that goes around the headlights (driver side). I did a search with no luck.
Old 03-22-2013, 05:49 AM
  #735
donnie_19's Avatar
Default oil cooler bypass
Any ideas of a part number for the one that can be d&t and vendor?
Attached Thumbnails Request Part Numbers-corvette-ls-oil-bypass-adapter.jpg   Request Part Numbers-corvette-ls-oil-bypass.jpg
Old 09-15-2013, 07:32 PM
  #736
Blue2KTA's Avatar
Default CD Changer Harness
I'm looking for the part number for the CD Changer harness that goes from the Monsoon radio to the GM CD changer for a 2000 Trans Am.
Thanks
Old 11-04-2013, 03:51 PM
  #737
saltwaterreefguy's Avatar
part number for front bumper support and headlight support its all one piece for a 93-97 trans am thanks!
Old 02-14-2014, 11:00 AM
  #738
BaD AZz Z28's Avatar
Originally Posted by LongIsland63SS409
Thank you for the part numbers received the engine mount cross bolt
11516940 12mmx1.75x160 grade10.9.
They do not come with the nuts.
Is there a GM part number for them?
Thanks,
Mike
Any update on the nut that goes with this thru-bolt for the motor mounts?
Thanks
Old 02-22-2014, 07:12 PM
  #739
slaterdump's Avatar
Does any one know the part number for a 1998 Fbody LS1 PCV hose assembly? I have found the part number for the 99-02, but cant find it for the 1998. Thanks
ETA
found it, 12560692.
Old 03-06-2014, 10:54 AM
  #740
FYI according to another forum:
Motor Mount Through Bolts
11516940 Bolt 2 M12 x 1.75 x 160
11515744 Nut 2 M12 x 1.75
Quick Reply: Request Part Numbers
