Request Part Numbers
Old 04-07-2014, 10:20 AM
  #741
fivepointfive's Avatar
New here--not even sure I am in the right place. Trying to get information on dropping a 5.3 into a 1954 Corvette. I have the truck engine, but looking for conversion parts like the power steering pump.
Old 04-09-2014, 08:32 PM
  #742
VR'92's Avatar
How about a serpentine belt for a 98-02 LS1 Camaro with AC delete?
Old 04-21-2014, 12:14 PM
  #743
skiziFiziks's Avatar
I am also using a truck motor for my swap and have purchased an accessory drive kit from GM for my swap.
You may find you are missing a bolt location on the drivers side of the block, if you are using an iron block truck engine. It is needed to mount some of the parts for car accessories.
The car I am using could benefit from any space I could save in front of the engine so I purchased a CTS-V accessory kit part # 19290770. Which includes new OEM brackets, hardware, serp belt, and the belt driven accessories like power steering pump/reservoir and alternator. The kit I chose is minus A/C and required I buy a different crank pulley.
GM has several kits with different options, I purchased my kit from Jegs and the suggested Balancer from amazon. I am using an aluminum L33 so I happen to have the needed tab and bolt location in place already.
Old 04-23-2014, 03:19 PM
  #744
MaverickFL's Avatar
Originally Posted by ACW
Front Wheel Well Liner (98-02 Firebird), RH = 10296523
Front Wheel Well Liner (98-02 Firebird), LH = 10296524
Front Wheel Well Liner (98-02 Camaro), RH = 10296525
Front Wheel Well Liner (98-02 Camaro), LH = 10296526
To add to this. Sometimes the right fasteners and screws can be as difficult to track down as the parts, so here's what I've found on this:
Retainers for wheel well liners are usually listed as GM 11589290, but these are push-in type. Mine were originally screw in type, so exact replacement is actually: GM 20664092.
Head Diameter:11/16"
Stem Length: 7/8"
Fits into 1/4" hole
Screw fasteners for wheel well liners are either #8 hex head with washer or M4.2-1.41 Hex Washer Head Sems Screw. I can't find the actual GM part number for these. I'm also not sure at this point if mine are original or not but mine are all self-tapping screw type.
Old 05-04-2014, 12:34 AM
  #745
Root2812's Avatar
I purchased my motor (5.3L) and Tranny separately for my swap and now that I am bolting it together I find that I am missing some stuff but don't know the name or part numbers. Does anyone know the part number or have a schematic for the plate that the starter passes through. You can see the black plate in the attached screen shot from a youtube video. I just have a gaping hole there. Is there one for the other side as well?
While I'm asking, Does anyone know what else goes between the tranny and engine? I have the fly wheel and torque converter but since the plate is missing I wonder if I might be missing something else. I'm a complete novice so I know basically nothing.
Thanks
Old 05-22-2014, 12:09 PM
  #746
DirtyBirdMKE's Avatar
I need the part# female socket with pigtail that goes into the headlight motor for a 98 firebird
I found what i think is the connector on amazon either PT284 or PT1015
Old 09-27-2014, 06:21 AM
  #747
Camaros-n-Chevelles's Avatar
Where can I cross reference a GM part number to an AC Delco part number?
I am looking for a water pump for my LS conversion and there are different part numbers out there. I am just trying to sort everything out.
What I did find so far is that a GM 19256263 is the same as an AC Delco 251-744. This water pump is for the 1997 - 2004 Corvette.
It looks like AC Delco 252-921 and GM 89018052 are the same water pump.
AC Delco 252-921 ~ LS1/LS2 pump
AC Delco 251-726 ~ LS7 pump
I just have to find the GM part number for AC Delco 251-726 and the AC Delco part number for GM 12604630.
I am looking to cross reference the following part numbers:
GM 89018052 and 12604630.
AC Delco 252-921 and 251-726 .
The GM 12604630 is the 2009 up water pump with the drivers outlet.
Any help is greatly appreciated.
Old 10-09-2014, 03:58 PM
  #748
JONBOY03's Avatar
To Camaros-n-Chevelles
Delco# 251-726=19180591
GM# 89018052=89018052 Delco# is same on some parts
GM# 12604630= Does not have Delco# and is only available inside a kit does not show it is available by its self.
Delco# 252-921= 88879876
Hope this helps out.
Roaten
Old 04-13-2015, 07:23 AM
  #749
727
727's Avatar
The AC belt is a separate belt .It runs the AC only.. So the serp wouldn't matter.
Old 04-13-2015, 07:32 AM
  #750
727
727's Avatar
Looks like a PT284
Old 05-05-2016, 10:49 PM
  #751
-=Modified=-'s Avatar
(2002 Camaro Manual) Steering Column Tilt Pivot Pin
Old 05-06-2016, 09:51 AM
  #752
727
727's Avatar
-=Modified=- I can email you a picture if you like .
Old 05-07-2016, 07:48 PM
  #753
Please do.
Old 05-26-2016, 08:11 PM
  #754
Wnts2Go10O's Avatar
01-02 Camaro underhood fuse block part numbers if at all possible.
Old 05-27-2016, 06:24 AM
  #755
727
727's Avatar
12176369 . Looks like it goes in the left front. There are two of them,same part # . It's still available,too.
Old 05-28-2016, 03:42 AM
  #756
Wnts2Go10O's Avatar
How about the post the battery cable bolts to on the junction box?
I'm actually putting a box together from scratch for another project.
Old 05-28-2016, 07:37 AM
  #757
727
727's Avatar
Old 05-31-2016, 05:31 PM
  #758
Wnts2Go10O's Avatar
how about the buss bar terminals that connect to the post?
Old 06-01-2016, 06:35 AM
  #759
727
727's Avatar
Looks like a 6 hole is 12146182 and a 5 hole is 12129481 .Or I could e mail you a picture.
Old 06-01-2016, 03:44 PM
  #760
Wnts2Go10O's Avatar
Might as well add all the part numbers for the terminals, box, etc
Quick Reply: Request Part Numbers
