Request Part Numbers
Old 12-11-2005, 01:03 AM
  #61
ACW
ACW's Avatar
Originally Posted by racer7088
LT1 oil galley internal 12mm ball bearing GM plug?
Can you find the number for this? No one else seems to be able to? I had it but we lost it. Its the internal oil galley plug that diverts oil to the oil filter and is a 12mm stanless steel ball bearing from GM. Thanks very much ahead of time!
This is a difficult one... looked through my stuff for a while without finding it, then after quite a bit of searching online, found that apparently the bearing for the last main cap diverts oil to the oil filter.
10120993 is listed as being the LT1 (93-97) #5 main bearing; hopefully that's what you're looking for...?
Old 12-11-2005, 05:59 AM
  #62
racer7088's Avatar
Thumbs up
Well it is a ball bearing that goes underneath the number 5 main cap. I will have to see or just get it at the dealer and see what it is?
Old 12-12-2005, 07:51 PM
  #63
Cephiros's Avatar
There's several possibilities for the interior door panel. Cloth or leather? Which entertainment package RPO (affects speaker placement) do you have -- W53, W54, W55, X10, or X20?
i dont know what this guy has, but i need the same part, leather, W54 RPO, 2000 year if it matters
Old 12-12-2005, 10:24 PM
  #64
ACW
ACW's Avatar
2000 (also 2001) Firebird/TA
body style F87 (Coupe)
black/ebony leather (RPO 192 or 193)
RPO W54 (also W55) entertainment package
front side door interior trim panel, RH (passenger) = 12458755
front side door interior trim panel, LH (driver) = 12458756
Old 12-13-2005, 02:17 PM
  #65
BackinBlack02SS's Avatar
2002 LS1 Camaro valve cover gaskets.
Old 12-13-2005, 09:32 PM
  #66
ACW
ACW's Avatar
LS1 valve cover gasket (99-02) = 12560696
Old 12-17-2005, 12:22 AM
  #67
teh PuRpL3z
DrEvyl's Avatar
It was just in a thread in here the other day, but I can't find it now, and I've looked up and down and sideways through the forum..
I need the part number for the nose insert for a Firebird... the insert with the "bird" on it that covers where the license plate goes.
I also need for a '98 Trans Am:
Emergency Brake handle ('98 pewter leather)
Driver's seat cover ('98 pewter leather, standard non-articulating seats)
Driver's seat cushion
'98 WS6 exhaust (one on the left style)
Old 12-17-2005, 01:52 AM
  #68
ACW
ACW's Avatar
Firebird front license plate cover with bird (comes flat black, paint to match) = 10276353
Parking brake handle doesn't seem to be available to match the upholstery:
Firebird parking brake lever handle (grip portion) (97-99 NP5) = 10291075
Pewter isn't a leather color name... do you mean 'neutral'/taupe?
Firebird driver seat cushion cover, neutral (98-02) = 16813656
Firebird driver seat cushion pad (97-02 AQ9) = 16794382
LS1 WS6 exhaust muffler with tail pipe (single) (98 WS6), with polished tip = 10436321
LS1 WS6 exhaust muffler with tail pipe (single) (98 WS6), with non-polished tip = 10409537
Old 12-17-2005, 07:38 AM
  #69
teh PuRpL3z
DrEvyl's Avatar
Thanks, man
To answer your questions...
If I'm not mistaken, I think they only came in 1 color.
The window sticker for the car lists the interior color as "dark pewter", I've also seen it referred to as "graphite".
This color:
Old 12-17-2005, 08:58 AM
  #70
gex
gex's Avatar
LT1 fuel rail crossover tube with orings and brackets
Thanks
Jason
Old 12-17-2005, 10:39 AM
  #71
teh PuRpL3z
DrEvyl's Avatar
Oh, BTW... my seats are AR9 seats, not AQ9. Do you have those part numbers too?
P.S. Holy crap, that catback assembly is $370!
Old 12-18-2005, 02:04 PM
  #72
ACW
ACW's Avatar
Good
This color:
http://pics.evyl.org/PurpleTA/BPM_98-WS6_16.jpg
Yeah, they can't seem to stay with consistent terms for those interior colors!
Yep!
Looks like the closest choice listed for 98-99 is 'light gray' leather (143, AR9) driver seat cushion cover = 16813656
Don't know which of these is what you'd need, though:
driver seat cushion pad (98-02 AR9):
with wire = 16729508
without wire = 17908778
Many of the OEM parts aren't cheap
Old 12-18-2005, 02:20 PM
  #73
ACW
ACW's Avatar
94-97 LT1
fuel crossover tube: included in kit 9
crossover tube retainer: included in kit 9
o-ring seals for tube: included in kit 8
service kit 8: fuel rail seal kit (AC-Delco #217-449) = 17113086
service kit 9: fuel rail crossover tube kit = 17113092
It looks like the part number might have changed for the crossover tube kit; a dealership should be able to use the old number to look up what it's changed to.
Old 12-28-2005, 10:55 AM
  #74
Abe99's Avatar
I need the part number for the flywheel bolts and the pressure plate bolts for a 2000 TA with T56.
Thanks
Abe
Old 12-28-2005, 08:38 PM
  #75
ACW
ACW's Avatar
Thanks
Abe
M6 flywheel bolts (hfh, m11x1.5x23.5, 21 thd, 22 o.d., with sealant) (98-02 LS1) = 12553332
M6 clutch pressure plate bolts (hfh, m10x1.5x25, hdr pt, 17.3 flange) (98-02 LS1) = 12561465
Old 01-05-2006, 09:05 PM
  #76
Upper passenger side ebony leather seat cover for a 2002 Camaro SS
Old 01-05-2006, 11:02 PM
  #77
MM98's Avatar
Part#16837696
Mike
Old 01-05-2006, 11:05 PM
  #78
Originally Posted by MM98
Part#16837696
Mike
If that is the correct part number, then what is 16837707?
Old 01-05-2006, 11:07 PM
  #79
MM98's Avatar
That would be the head rest cover on a TA seat.
Old 01-05-2006, 11:18 PM
  #80
ACW
ACW's Avatar
Part#16837696
Mike knows what he's talking about, but to confirm since you're unsure, 16837696 is for an Ebony Passenger Seat Back Cushion Cover (00-02 Camaro), for black leather RPO 192 or 193, and seat reclining RPO AR9.
Quick Reply: Request Part Numbers
