Request Part Numbers
Old 01-24-2006, 06:10 AM
  #101
ACW
ACW's Avatar
Originally Posted by DrewSG
Anyone know the part number for the gas cap? I lost mine and the two posted in thread don't work at GMPD.
I have current numbers for 93-97 and 98, but those don't help you... For 99-02, I have previous GM numbers and current AC-Delco numbers, but haven't been able to find the GM numbers that go with them. Try calling a dealership and they should be able to cross-reference these to what the number have changed again to. Post it up if you find out anything.
gas cap ('fuel tank filler cap') (93-97) (AC-Delco #GT174) = 10164142
gas cap (with tether) (98) (AC-Delco #GT222) = 22616291
gas cap (with long tether) (99-02) = 22616287 (discontinued for short version)
gas cap (with short tether) (99-02) (A-D #GT261) = ? (form. 22660003, 22616286)
gas cap (without tether) (99-02) (AC-Delco #12F58) = ?
locking gas cap (99-02) (A-D #GT270 or 12F31L) = ? (formerly 22660006, 22616294)
Old 01-24-2006, 06:50 AM
  #102
Super Speed's Avatar
Gimme the part numbers for the Passenger side manifold AIR gasket and the drivers side seatbelt plastic D looking thing that goes on the side of the seat that hold the seatbelt at a lower place, thanks!
Old 01-25-2006, 02:03 AM
  #103
ACW
ACW's Avatar
Left out what car! I had to look through a bunch of your posts to find out it's a 2000 Camaro SS.
LS1 Secondary Air Injection (AIR) pipe gasket (98-02) = 12553617
(It's the same for both sides.)
What color is your interior? Left that out too Should be one of these:
front seat shoulder belt guide (96-02 coupe), neutral, LH = 16789715
front seat shoulder belt guide (97-02 coupe), pewter, LH = 16799275
front seat shoulder belt guide (00-02 coupe), ebony, LH = 16817201
Old 01-25-2006, 08:23 AM
  #104
byrontaylor's Avatar
ACW, when you get a chance there are a few PN's I need to know for a friend...first the covers for a 35th ann. camaro for the rear seats. You had the front but not the back, second, 35th silver stripes, and last, the chrome ss wheels or wheel and tire sets for myself.
Old 01-25-2006, 12:12 PM
  #105
BackinBlack02SS's Avatar
By chrome SS wheels do you mean 10 spokes or ZR1 style? Both were made only by SLP, not GM. The chrome 10 spokes have been discontinued, but I believe you can still purchase the chrome ZR1 wheels from SLP.
Old 01-26-2006, 03:17 AM
  #106
ACW
ACW's Avatar
Camaro rear seat cushion cover (35th Anniv SS - ebony w. gray center, RPO 193) = 88899199
Camaro rear seat back cover (35th Anniv SS - ebony with gray center, RPO 193) = 88899188
35th Anniversary stripes:
10307873 - Front Fascia Stripes
10307874 - Front Fascia Lower Stripes
10307867 - LH Hood Stripe
10307866 - RH Hood Stripe
10310679 - LH Decklid Center Stripe (Convertible)
10310678 - RH Decklid Center Stripe (Convertible)
10307875 - LH Decklid Center Stripe (Coupe)
10307876 - RH Decklid Center Stripe (Coupe)
10307877 - LH Spoiler Stripe
10307878 - RH Spoiler Stripe
I've never seen GM part numbers for them, whether they're still available or not. I also haven't seen GM part numbers for any tires.
Here's SLP and a couple other sponsors that sell the chrome Camaro SS SLP ZR1 wheels:
http://www.slponline.com/view_product.asp?P=80041
http://www.lmperformance.com/746/1.html
http://www.afterthoughtsauto.com/chrome-ss-wheels.html
The non-chrome ("Machine Polished Face") 10-spoke SS wheels (35th Anniversary) are available and have part numbers, but that's not what you wanted.
Old 01-26-2006, 09:34 AM
  #107
Thanks alot ACW, the GMPD is changing PN's I guess and their's wouldn't work on about half the stuff. If I find anything has changed I'll let you know.
thanks again
Byron
Old 01-29-2006, 11:53 PM
  #108
SSideExhLS1's Avatar
i have a part number that i cant seem to find anywhere, the GM# is 16523943 it is a bracket where the two headlamps mount on a 2001 Trans Am. if this is no longer available, then whats the part number to the entire headlamp assemblies for this vehicle, both right and left???
thank you very much!!!!!
Old 01-30-2006, 02:32 AM
  #109
ACW
ACW's Avatar
Where did you come up with that number from in the first place? Seems to be an incorrect number.
Is this what you're looking for?
Firebird headlamp housing panel upper bracket (98-02) = 10247777
Or this?
Firebird headlamp support (98-02), RH = 10414795
Firebird headlamp support (98-02), LH = 10414796
Old 01-30-2006, 04:54 AM
  #110
99whitews6's Avatar
Part number for crankshaft key for a 99 Trans Am Ws6? The key that slides into the crank keyway to hold the timing sprocket in place.
Also, part number for bellhousing dowel pins that align the bellhousing to the tranny.
Thanks
Old 01-30-2006, 08:52 AM
  #111
02WS6Bird's Avatar
How about the Bolts to the Oil Pan. I somehow managed to break one of the 2 in the back (the very long bolts) if you could please let me know
Old 01-30-2006, 10:52 AM
  #112
Or this?
it is the bracket where you actually screw on both headlights, its whats right behind the plastic bezel. and its in front of the bracket that mounts to the upper radiator support. if it helps, this bracket contains one small spring for each headlamp, i guess they are to adjust the headlamps. i got the part number from the actual piece. thanks for your help!!!!
Old 01-30-2006, 07:09 PM
  #113
MM98's Avatar
Thanks
Crank key- part#12561513
Dowel pins- part#1453658
Old 01-30-2006, 07:10 PM
  #114
MM98's Avatar
Rear pan bolts- part#12554990
Old 01-30-2006, 07:20 PM
  #115
MM98's Avatar
Yeah that part is not serviced through GM... It's part of the headlight assm...
LH Assm- part#12336001
RH Assm- part#12336000
Old 01-30-2006, 07:48 PM
  #116
99whitews6's Avatar
LS2 lifter tray part number?
Old 01-30-2006, 08:17 PM
  #117
MM98's Avatar
Part#12595365
Old 02-01-2006, 07:32 AM
  #118
Ωmega's Avatar
Does anyone know the part number for the clips that hold the tranny cooler hard lines in the trans?
Old 02-01-2006, 08:32 AM
  #119
BLUE99T/A's Avatar
I can't seem to find a # for the knock sensor wiring harness. Damn plastic end broke off. thanks. 99 fbod
Old 02-01-2006, 08:40 AM
  #120
TRANSAM75's Avatar
Knock Sensor Harness #12597415
Quick Reply: Request Part Numbers
