Request Part Numbers
#121
EDIT: Anyone know the gm part number for the red vaccum cap pictured here? http://www.ls1howto.com/howto/genii...gerside_pcv.jpg They came with the LS6 valley cover, and I believe the C5 Z06 from the factory.
#123
#126
could someone pm me the part number for the interior piece(the opening is about 2"x4") right in front of the shifter(m6)? my interior is ebony and model year is 2002.
also, who about the plastic fastners that hold the interior piece that covers the spare tire?
thanks in advance.
justin
thanks in advance.
justin
#127
Originally Posted by SSideExhLS1
i got the part number from the actual piece.
#128
http://www.ls1howto.com/index.php?article=18 says the size you need:
[one] 5/16" vacuum cap, if your LS6 cover doesn't come with a red one pre-installed
If for some odd reason your LS6 cover didn't come with one, any autoparts store will have one for a buck or two. You should need a 5/16" cap.
#129
Originally Posted by ACW
Left out what car! I had to look through a bunch of your posts to find out it's a 2000 Camaro SS.
LS1 Secondary Air Injection (AIR) pipe gasket (98-02) = 12553617
(It's the same for both sides.)
What color is your interior? Left that out too Should be one of these:
front seat shoulder belt guide (96-02 coupe), neutral, LH = 16789715
front seat shoulder belt guide (97-02 coupe), pewter, LH = 16799275
front seat shoulder belt guide (00-02 coupe), ebony, LH = 16817201
oh hbout the passenger side air bolt? Thanks!
#132
Originally Posted by silver z28
On the center consol in a 2000 camaro. The door for the ash tray, that opens and closes. What’s the part number for just the door.
Thanks.
Thanks.
ashtray lid/cover, auto trans (97-02) = 10408634
#133
ashtray, manual trans (00-02) = 10261420
ashtray lid/cover, manual trans (97-02) = 10271366
No choice on color, so might not exactly match.
thanks in advance.
justin
thanks in advance.
justin
rear compartment trim retainer (fits 0.25 hole, 1.01 lg, nylon, black) (93-02) = 10121502
#134
Originally Posted by LS1 GG
Thanks a bunch man
LS1 Secondary Air Injection (AIR) pipe bolt (98-02) (m8x1.25x24.4, 20 thd) = 12556127
#135
Sounds like the ashtray..? Not sure if you want the compartment piece or the cover for it, though.
I think I looked that up before and it was this:
thanks for the help.
#136
I NEED these part numbers:
-The part number for one of the four bolts that connects the wheel hub, to the steering knuckle/spindle. I need to order one, but I don't know the part number.
-The metal retainer clips that hold the transmission cooler lines into the transmission. I lost one of mine, and once again do not have the number.
Please help. Thank you.
Adam
Adam
#137
Adam
Adam
#139
ACW,
thanks im halfway there knowing the fastner part number. im looking for the interior piece that is located in front of the shifter(towards the engine). it is underneath the hvac controls. i put a hole in mine for a air/fuel gage that im going to relocate.
thanks in advance.
thanks in advance.
#140
ACW,
thanks in advance.
thanks in advance.
If so, that's one of those tricky ones with incomplete listings and a number of different variations, but I think I finally have them figured out:
switch plate (by lighter), 1 opening (for TCS) (no logo) = 10280509
switch plate (by lighter), 1 opening (for TCS) (Pontiac) = 10411289
switch plate (by lighter), 1 opening (for convertible top) (no logo) = 10280510
switch plate (by lighter), 1 opening (for convertible top) (Pontiac) = 10411284
switch plate (by lighter), 2 openings (for TCS and convertible top) (no logo) = 10280511
switch plate (by lighter), 2 openings (for TCS and convertible top) (Pontiac) = 10411285
