When I stomp on the gas, there isn’t much power
Old 02-03-2006, 09:48 AM
haneyt's Avatar
Default When I stomp on the gas, Their isn’t much power?????
I have a 99 T/A m6. I have had my car for a little over a year, when i first got it, i would stomp the gas and i could feel the power, but now when i get on it, it just doesnt seem to have that power any more, it sounds like im going fast from the motor, but i barly accerlerate like i did when i fist got the car......
Old 02-03-2006, 10:04 AM
Aegnor's Avatar
Sounds like the clutch is slipping.
Old 02-03-2006, 10:14 AM
RICEETER's Avatar
yeah, could be the cluth. OR the most common problem, people just get used to the power and the way their car runs and it just seems like its less to you. im that way with alot of things, i used to have a big stereo system and after a while it just seemed that it wasnt as loud. it was just me getting used to it. i was the same way about the power in my car. hope nothing's wrong with your car.
Old 02-03-2006, 10:32 AM
jwhert's Avatar
its not getting use to the stereo, its hearing loss from using the stereo
Old 02-03-2006, 10:51 AM
z28convert's Avatar
Old 02-03-2006, 10:55 AM
haneyt's Avatar
I am starting to think its my clutch now, after talking to some one at work, they said if my rpm's are rasising fast then it might be the clutch. Is this true? Also my clutch pedel feels like mushe or some thing.
Old 02-03-2006, 04:03 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
most likely a slip on the clutch.
Old 02-03-2006, 04:13 PM
haneyt's Avatar
Hmm, so is it hard to change a clutch? Should i change the flywheel to, or any thing else to do with the clutch? My car has 75,000 miles.
Old 02-03-2006, 04:25 PM
y2k1blkss's Avatar
when changing clutch, i believe you'll need to re-surface the flywheel. Also I heard you might have to shim the bell housing now that you just re-surface the flywheel, and bleed the clutch.
Old 02-03-2006, 06:13 PM
ls1greyhound's Avatar
If your clutch is slipping that bad you should smell it
Old 02-03-2006, 08:05 PM
SUX2BU's Avatar
put it in 6th gear while cruising at around 60 mph and punch it. if the rpms "float" up then your clucth is toast.
Old 02-03-2006, 08:49 PM
GuitsBoy's Avatar
Im only judging by the title of your thread, but... Sounds like youre driving a ford.
Old 02-04-2006, 10:48 AM
haneyt's Avatar
I will have to try this........What would yall say a good clutch would be to buy? Should i but a new flywheel to?
Old 02-04-2006, 11:18 AM
GuitsBoy's Avatar
If youre not highly modded, the c5 z06 clutch kit (ls6 clutch) is the best bang for the buck. It can be had for under 400 bucks including the clutch, pressure plate, and a new flywheel. If youve got a bit more HP to hold, you can try the new ls7 clutch but its a bit more pricey and requires buying an ls2 flywheel for a c6 vette in order to work with an f-body. Either way you should upgrade to the 2002 hydraulics (master / slave). Both clutches should be chatter free, hold a good deal of power, and have stock like street manners and durability since theyre factory clutches.
Old 02-04-2006, 11:32 AM
haneyt's Avatar
I am all stock right now, i have 74,000 miles, and i dont plan on doing more than maybe exhuast and a few other bolt ons, may be a cam.......where is the best place to but theses kits from?
What would have to do to ungrade to the new mast/slave?
Old 02-04-2006, 11:43 AM
GuitsBoy's Avatar
Try fred beans or SDPC. I dont have the part number off hand, but they should be easy enough to find. Youll have good luck with the cheaper z06 clucth kit. The slave will be easy enough to replace when youve got the tranny out to replace the clutch. The master is under through the firewall and just has a U bolt holding it in.
Old 02-04-2006, 11:56 AM
haneyt's Avatar
Is their any other things i should change while i have the tranny out, the through out bearing or any thing like that?
Do i need to do that drill mod thing too?
Old 02-04-2006, 01:26 PM
Zymosis's Avatar
You could do the drill mod, and get new slave while you are in there (fairly cheap, like 110 or so)
Old 02-04-2006, 01:39 PM
98boxer's Avatar
....the loudmouth exhuast was so damn loud when I first had it installed I thought of removing it and loudmouth replaced the slowmaster muffler. I always thought some how the exhuast quieted down by itself cause after 3 weeks the noise wasn't as bad and now it way more enjoyable then when I first installed the loudmouth exhuast. And this wasn't the case with the slowmaster.
Old 02-04-2006, 02:34 PM
skiptomylue's Avatar
or it may be your optispark and or distributor cap, i had the same type of problem with my car, sounds like its going fast, but its not going anywhere, if its your optispark.. well.... that sucks.. they are kinda pricey
