What does a throttle body do?
Old 02-24-2006, 05:09 PM
fire_boy06's Avatar
Default What does a throttle body do?
What does a throttle body do and what would you gain by modding the stock one?
Old 02-24-2006, 05:16 PM
Possible Scammer - Buyer Beware - Issues Unresolved
00ls1's Avatar
it controls the amount of air that goes into the engine. your gas pedal is comnnecte3d to it by a wire, the more you press the gas pedal the more the TB opens.
Old 02-24-2006, 05:18 PM
sdbrown84's Avatar
Modding the stock one will usually yeild a noticible gain in both HP and TQ. It will allow more air into the engine with less of a restriction.
Old 02-24-2006, 10:28 PM
Ric
Ric's Avatar
It's your modern-day carburetor. Port it right, and it'll flow more air, telling the PCM to shoot more gas, which makes more pahr.
Old 02-24-2006, 11:12 PM
MountainMotor's Avatar
I agree with all 3. A lot of people port the stock throttle body, which will give ya some gain but some step up to a larger intake manifold which requires a larger than stock throttle body. If your sticking with an LS1 or LS6 intake then I'd just port the stock throttle body, should be sufficient unless your planning on running a lot of power, in which most cases people step up to a larger intake and throttle body anyway.
Old 02-24-2006, 11:23 PM
ShevrolayZ28's Avatar
Originally Posted by Ric
.....which makes more pahr.
...you mean powah?
Old 02-25-2006, 08:38 AM
v8hunter's Avatar
It regulates the amount of air into the motor...it is similar to a carb on an older car (except that the carb injects fuel as well). A ported throttle body allows you motor to injest more air so you can make more horsepower
reminds me of when my sister asked what oil does in a motor
Old 02-25-2006, 08:50 PM
RrCoX22's Avatar
what does it do???
Old 02-26-2006, 01:31 AM
HowellSoccer88's Avatar
one thing you will probably see too is more throttle > more air > more gas > less gas mileage
Old 02-26-2006, 03:13 AM
Azrael's Avatar
Our ported TB before it went on:
Old 03-01-2006, 05:12 PM
lt1camaro95's Avatar
It throttles the body.
Old 03-01-2006, 10:30 PM
777's Avatar
Originally Posted by ShevrolayZ28
...you mean powah?
...you mean POWER
Old 03-02-2006, 12:51 AM
99camarosupersport's Avatar
that's his g/fs job, not the car. but everyone above is right, more air. port the stock one, or if you dont know how they are for sale on the boards.
Old 03-02-2006, 05:53 AM
'99slobird's Avatar
Right on, brother.
Old 03-02-2006, 02:48 PM
Black Z/28's Avatar
Actually, it's a body that throttles.
Quick Reply: What does a throttle body do?
