should I buy this car
Old 03-10-2006, 08:24 PM
lowc10's Avatar
Default should I buy this car
I am looking at this ta and the guy changed the heads out and it wont run. I was told that he said oil wont get up to the heads. What do you think could be wrong? Also should I buy the car or not?
Old 03-10-2006, 08:28 PM
Nimitz87's Avatar
for what price?
why dont you start off with a clean stock car...much less hastle.
Chad
Old 03-10-2006, 08:32 PM
lowc10's Avatar
The price on the car is real good. I am good with old 350's but never worked on a newer one.
Old 03-10-2006, 08:38 PM
smmurf86's Avatar
well if oil wont get to the heads then wouldnt that be a bad oil pump..maybe the screw broke off that holds it in place...if oil isnt getting to the heads then i wonder where else is it not getting too, might need all new bearings as well...i agree dont start off with a headache
Old 03-10-2006, 08:48 PM
lowc10's Avatar
Yeah I was thinking about the shaft on the oil pump maybe, I always go to steel. Well the price of the car is worth picking up just to check it out. I already have something to drive.
Old 03-10-2006, 08:53 PM
M6HuggerSS's Avatar
you need to post more info on the car and price.....
i ll just guess since i dont know what car or price it is.....
if it was a 98-00 Z28..... id say, if you really like the car.... give him $5K for it.....
and just throw in a $4K shortblock.... maybe a 402?
and go from there.....
Old 03-10-2006, 08:55 PM
2K2WS6TA's Avatar
FWIW unless you want a project car (and it sounds like you might) this sounds pretty good (depending on th price) get the car, grab a forged short block, add heads and cam of your choice, and top it off with the giggle gas
Old 03-10-2006, 08:56 PM
lowc10's Avatar
98 ta for 2000 sat for 6 months since he changed the heads
Old 03-10-2006, 08:58 PM
swoleguy's Avatar
Wow dude, how do you know he,s not lying to you?It,s your decision but I would pass on it.
Old 03-10-2006, 08:59 PM
lowc10's Avatar
I'm not realy looking for a project car. It would be a project till I get it running. I want to make it a daily and park the truck.
Old 03-10-2006, 09:56 PM
Shirley Temple Drinker
Sgt. Spuds's Avatar
2 grand!!!!
Holy ****, get that. Throw a blown 402 in there and have one of the baddest cars out there for like 10 grand...
Old 03-10-2006, 10:03 PM
lowc10's Avatar
haha that would get worse gas mileage than my truck. I want a fast car but reliable. My truck isn't that reliable being old. So I figured I would look into the car.
Old 03-10-2006, 10:10 PM
SnakesRslow's Avatar
fyi, there is no shaft to drive the ls1 oil pump. It is mounted on the crank behind the harmonic balancer
Old 03-10-2006, 10:38 PM
99camarosupersport's Avatar
worry about reliable on the truck, fast cars aren't meant to get 30 mpg
Old 03-10-2006, 11:00 PM
lowc10's Avatar
It will be way better than my truck, 355 with 490 lift @ 290 297 112* seperation cam, flat top pistons, 0 deck clearance, worked heads, crane gold series roller rockers, 110 gph holley fuel pump, 750 cfm edelbrock carb, perormer rpm intake with 1" carb spacer. With aerodynamics of a brick.
Old 03-10-2006, 11:11 PM
FunkyTownFBody's Avatar
Blown 402 would still get better gas milage than a carbed 355!
With the right tune you could still get 19 on the highway, 13-14ish in the city if you drive it right! Pshhh if you won't do it, I will... where is this guy lol.
