Best forum for overall engine/vehicle combination questions?
Old 03-19-2006, 09:20 AM
Gannet's Avatar
Default Best forum for overall engine/vehicle combination questions?
Let's say you're starting with a stock car, and you have some overall performance goals in mind, but you aren't fixed on how to get there. Bolt-ons, stroker, power-adder, driveline mods, combo of these, etc. What's the best forum for this type of question or discussion?
Old 03-19-2006, 10:09 AM
Allergik2dyin's Avatar
That's why there's individual sections for each category you just mentioned. ie the internals section for heads/cams etc, forced induction for turbos and s/c's, and then farther down the gears and axels section. Go through each section and read the stickeys for a general idea about the section and post accordingly. Posting in the correct section, depending on what mods you want to do, will increase your chances of only having to do a mod once. Good luck.
Old 03-19-2006, 10:59 AM
Gannet's Avatar
If you post in each individual section, then that won't be about the overall combination, now will it? Cams go with heads which go with shortblocks which go with trannys which go with rear ends, all of which may or may not go with a power adder. And yes, I've read the stickys, and I'm currently using search.
Old 03-19-2006, 12:09 PM
jrp
SN95 Director
jrp's Avatar
there is no overall all forum. you have to tell us your goals and application when posting about specifics.
