Trans Am with speedometer only 120mph?
Old 04-26-2006, 07:33 PM
gilley_77's Avatar
Default Trans Am with speedometer only 120mph?
Just a quick question. I recently purchased a 94 auto T/A. Its definitly a 5.7L, but my speedometer only registers to 110 or 120 (cant remember which right now since Im not looking at it, but I know its not more than 120.) Did this come stock, or has the cluster been changed? Thanks for any answers anyone may have.
Old 04-26-2006, 08:15 PM
98hardtopZ's Avatar
i know in the ls1's the v6's only go to 120...so it might of been
Old 04-26-2006, 08:44 PM
Ell Ess Won's Avatar
if its a factory Trans Am 5.7, it should read 150.
Old 04-26-2006, 09:09 PM
TransAm8723's Avatar
i believe I've seen a few early 93-95 4th gens with 110-120 speedos, rarely though...
Jeremy
Old 04-26-2006, 09:19 PM
RobZ28's Avatar
I'm not sure where but I'm sure I read that if the car wasn't ordered from the Factory with Z Rated tires, The speedomoter only goes to 120 and it has like a 108MPH Speed limiter. Check on your door and see if the sticker has a Z rating on the tire size. If not, I guess what I read was true.
Old 04-27-2006, 06:49 AM
Twisted-Method's Avatar
It is stock. I have a 94 T/A as well and it's the same...I think 110. The GT T/A's I believe went up to 150, but the regular T/A's had the 110.
*EDIT* - Heres a pic of mine.
Old 04-27-2006, 09:09 AM
Justin00SS's Avatar
Old 04-27-2006, 10:29 AM
bics56's Avatar
I heard the same
Old 04-27-2006, 12:54 PM
MavrikTA's Avatar
DITTO THAT^^ Alot of 93-94's have low speed counters.
Old 04-27-2006, 12:58 PM
1994Z28Lt1's Avatar
make sure the 8th vin digit is a P which is for the LT1 so you will know for sure if it is an original v8 car
if it is its definitely possible that if it didn't come with z rated tires that a lower speed cluster was installed from the factory i have seen in both ways i know of 95 camaros with limiters at 115 with 150 mph speedos
Old 04-27-2006, 01:19 PM
sandro arellano's Avatar
no, they are right.... there are a few with the 120 speedo but they are in fact v8's
Old 04-27-2006, 04:35 PM
J E T's Avatar
I think '95 was the year when they bumped it to 150. So '93-94's has 110 or 120 speedo.
Old 04-27-2006, 04:55 PM
infinitebird's Avatar
no most 93-94s had the 150 also. As stated above, if the original tires were not z-rated a 110 cluster was installed and it has a 108 speed limiter.
Old 04-27-2006, 05:03 PM
Justin00SS's Avatar
You have to go by the RPO codes. Some were speed limited cars like you said but its also listed on the inside of the door. The speedo doesn't reall matter.
I know a guy that used to have a 00 camaro z28 a4 that was limited to 115mph or something. His speedo when to 150. He was like damn my v6 mustang was limited to 117.
Old 04-27-2006, 07:38 PM
98hardtopZ's Avatar
my mistake...what the hell was i thinking?...why did i say ls1?..im really not an idiot.. What i really meant was, i know that in the late model v6's 3.8L, it only goes to 120..
Quick Reply: Trans Am with speedometer only 120mph?
