Advice??? (cam, hood, ewp, nitrous)
I have some extra money (2-3k) that I am trying to decide what to do with. My current considerations are below (see signature for current mods):
Cam & possible heads (something that will match my 3400 stall)
Ram air hood (still researching which one looks the best)
nitrous system with safety accys (I'm thinking a 100 hp dry system)
New brake pads & rotors (my rotors are slightly warped)
Built auto tranny
ewp
fast 90 / 90 setup (with nw tb)
12 bolt rear
If I had any tranny or rear end problems I'd probably get a better one of those, but there is no reason to fix something that isn't broken (yet). Then I thought that I'd get a cam and possibly heads, but about 6-12 months down the road I will probably do a stroker and those will most likely not be the same specs as I would want on my current set-up. The electric water pump doesn't seem like its probably worth the gain and a 90/90 setup would take away some of my low end. That leaves a dry nitrous kit, a ram air hood (list which one you like), and new brake pads/rotors. Do you think I'm heading in the right direction?
Built auto tranny
ewp
12 bolt rear
