Just cause I'm curious, 98-00 w/ls6, or 01-02?
I was thinking about this and I'm curious about it. I know they changed the cam in the 01-02 LS1's, but I don't know how much it affected it. Would a 98-00 engine with the ls6 intake or a stock 01-02 engine be more powerful?
the 98-00 would have advantage. the 01-02's have only the intake manifold for better equipment. the cams is actually alil weaker. wouldnt think it to be that noticeble though just slightly.
The '00 actually had the good exhaust manifolds as well. Which is why without a tune some guys argue that the gain felt with LTs and NO tune is minimal, vs on a 98-99 where the stock manifolds were more of a holding back point. Just my opinion, but I didn't put two and two together about the bigger cam AND LS6 manifold, very interesting.
-J
-J
2000 Z28 M6 Stock manifolds, cats, and Y-pipe....334 RWHP 340 RWTQ with mods in sig. The only mods made with HPTuners was turning off EGR, changed the fans, CAGS delete and limiting max WOT timing to 26 degrees as opposed to the stock 28 degrees because the engine likes to detonate at 28 degrees. No fuel changes with stock fueling AFR was 12.4:1
So they put the smaller cam in in '00, but they didn't change it to the LS6 intake until '01 o_O? I thought they changed them both the same year?
im looking at my book right now- how to build hi perf chevy ls1/ls6 following are specs for cams
f- body's
1998-pn12557812. duration degrees's at .05in in/exh 198/209. lift in/exh .500/.500 lobe centerline (degrees)119.5
1999-2000 pn12560965 198/209 .500/.500 119.5 same as 98's
2001-2002 pn12561721 196/207 .467/.479 116
y body's
97-98 pn12554710 199/207 .472/.479 117
98-99 pn12560964 same specs as previous just diff pn
00 pn12560968 198/209 .500/.500 115.5
01-03 pn12561721 198/207 .467/.479 116
ls6 y body
01 pn12560950 204/211 .525/.525 116
02-04 pn12565308 204/218 .555/.551 117.5
lr4&lm7 (trucks)
99 pn12560966 191/190 .457/.466 115.5
ok im not adding pn's anymore just years and specs
00-04 lr4+03-04 lm7 191/190 .457/.466 114
lq4
99-00 191/190 .457/.466 114
01-04 196/207 .467/.479 116
lq9
02-03 same as 01-04 lq4
gmpp avalible cams
hot 219/228 .525/.525 112
asa 226/236 .525/.525 110
f- body's
y body's
ls6 y body
lr4&lm7 (trucks)
lq4
lq9
gmpp avalible cams
Originally Posted by Cory1970
I have a 98 and I went with 2000+ ported exhaust manifolds (black bird) and I will be hopefully getting an ls6 intake soon. Do you think i whill need a tune after that??
Copy & Paste Moderator
