CHANGE OIL light? I just changed it!
When I crank my car, the change oil light comes on. Sometimes it goes off before I get where I'm going, but it always comes on on startup. My last oil change was within I think the last 400 miles. I checked the dipstick and it was full of oil (at the top of the operating range I mean). Does this mean something is seriously wrong or can I get this code cleared so it doesn't annoy me everytime I start up. Can this mean my car is burning oil? or my oil pump is going out? Anyways need some help on this guys.
you need to turn the car on to the accessory, and pump the gas or brake I can't remember 3 times, the light will flash, and then when you turn on your car it will be off and start counting again.
I had no idea about this, how did you hear that, I only knew off holding the trip reset button.
Originally Posted by burnrubr88
you pump the gas (not brake) 3 times quickly, the light will flash and it will be gone. this method can be used w/ a lot of GM cars
At my work(GM Dealership) on most of the GM vehicles, you turn the key to on and then pump the gas pedal 3 times within 5 second to reset the counter. On some, I have to go through the radio controls.
