Car Won't Start
Car Won't Start
I went out this morning tried to start the car and nothing happened. Last night the car started with out a problem. I know it’s not a battery problem because there is 12.5 volts across the battery and the radio and lights work fine. When I turn the key gauges drop like normal and everything but the starter dose not do anything. It is just as if I had turned the key without pushing the clutch in. I can think of two things that it could be ether the starter went dead or the switch on the clutch stopped working. Can anyone advise me on where to look at this switch or how to tell if it is bad? Or maybe that it is just the starter and just to replace that. Oh and the car is a 99 Camaro SS
Thanks,
Adam
Thanks,
Adam
No luck, car is still dead. What is involved in replacing the clutch position switch? I see some sort of control box next to the clutch petal. I am assuming this is it. Do I just pull it out and put the new one in?
Thanks,
Adam
Thanks,
Adam
I dont have an M6 fbody, or an fbody at all yet. And I don't know what it is or what it's called on these cars.
Look for anything that comes in contact with the clutch pedal at full depression. I would be a lot more help if I could walk outside and look for myself.. but I can't
Also another thing to check is that all of your electrical connections are sound. Wiggle the wires on the starter and make sure they are tight and corrosion free. Also check the battery terminals and make sure they are tight and corrosion free, a starter draws a lot of amps. There may be a fuse inline with the starter or in your engine fuse box, I'm not for sure if there is or where it would be but check that also.
There is not a fuse in the box for the starter but there is a relay. I pulled it out and it looked fine but I am not sure how you tell if you have a bad relay or not. I will go check the wires on the starter now but I know the battery is fine it was the first thing I checked.
Thanks,
Adam
Thanks,
Adam
Thanks,
Adam
Thanks,
Adam
Push Start the car and clean your Key with a bit of wd40 .... before you go look at the parts ... are you the original owner ... is there an aftermarket alarm?
12.5 voltage is not a good test as amps may be lacking can you put down an electric window? ... I would pushstart to get it running, let it run a bit (drive somewhere) don't shut it off unless you are somewhere like home ... then see what ya have
if you a meter we can tell you what wires to probe to see if it is your starter is getting juice or not
when the battery cables come off the battery where they kind of dip down towards the engine, pull up on them or move them around while a friend tries to start the car. I had a cable or ground that was loose at one point and I had this exact problem, mostly happened when it rained.
Why should I try and push start the car? To push start I get someone to push the car and pop the clutch in first rite? Cleaned the key still no luck. I am not the original owner of the car but I have had it for 3 years and 30,000 miles. No aftermarket alarm.
Thanks,
Adam
Thanks,
Adam
Check the clutch switch, take the connector off the back and put an ohm meter on the connectors, if the resistance is infinite with the clutch not depressed, and the resistance changes when the clutch is depressed then the switch is ok, so then it looks like the battery or starter
Then check the battery ground cable for corrosion, clean both ends and re install, making sure both the ends are tight
When I look at the clutch petal there are two switches. One that is activated when the clutch is to the floor and one that is activated when the clutch is just sitting there. Witch one do I check. I will probably just go check both but witch one is it I am looking for.
Thanks,
Adam
Thanks,
Adam
Ok on the black switch that is pressed when the clutch is depressed the multi-meter reads 1 on all resistance scales at both switch positions. I am assuming this is its way of telling me infinite resistance. So I am guessing that means this switch is bad?
Thanks,
Adam
Thanks,
Adam
This really sounds like a bad battery or or an electrical connection problem to me. Check all the ground wires for tightness and corrosion. Give them a little tug to make sure they are not corroded off under the insulation. Ive seen corroded wires that will light lights but not handle the current draw of a starter. Pull the battery and have it tested at Advance Auto or the like. Good luck.
John
John
Had the battery checked and it is fine. I felt around on all the ground wires I could see and they all seemed fine. Anyone else have any input on the switch?
Thanks,
Adam
Thanks,
Adam
Update: I really need to have the car running tomorrow so I went and just got the switch since they would not be open tomorrow (it was only $10). Put it on and the car started rite away. Thanks everyone for your help.
Adam
Adam
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Adam
Adam
