V8 swap question
V8 swap question
Can you swap a V8 from a 95 Z28 into a 95 Base (3.4 V6) camaro without making a lot of alterations? Or will it have to be heavily modified to fit?
I did alot of research about this also. I found unless your looking into this as a side project it would be cheaper and easier to just buy something with an LS1 already in it.
Thanks for the input both of you. I have the know how. I also have to change out the rear end to hold the power and the other things you mentioned. I just have never done a swap from a V6 to a V8 so I didn't know whether or not I would have to change out the motor mounts or if it would even fit into the engine bay without altering the frame. But again thank you all for the replies.
you don't HAVE to change out the rear. all fbodys had the same rear, the v6 ones weren't posi though...a small number were.
