L18 F-body swap
Old 10-19-2006, 09:44 PM
Phoenix_Master's Avatar
Default L18 F-body swap
Is it possible? how are the clearances and what would need to be done to make it work?
A search only turned up a thread with not much info on the topic.
EDIT:I don't think this would be breaking any forums rules, here is an informative link I found when searching on the net:
http://www.thirdgen.org/techboard/en...-swap-3rd.html
Old 10-20-2006, 02:47 PM
.. It's a fricken 494 big block not some honda 4 banger.
The Vortec 8100 (RPO L18) is a V8 truck engine. It is a redesigned Chevrolet Big-Block engine and was introduced with the 2001 full-size pickup trucks. It retains the same bore centers as the old 7.4 L big-blocks, but stroke was upped by 9.4 mm to reach 8.1 L (8128 cc) for a total of 107.95 mm bore and 111 mm stroke. It is an all-iron engine (block and heads) with two valves per cylinder. Power output ranges from 225 hp to 340 hp (168 kW to 254 kW) and torque from 350 ft·lbf to 455 ft·lbf (475 N·m to 617 N·m). Vortec 8100s are built in Tonawanda, New York.
L18 Applications:
Chevrolet Avalanche
Chevrolet Silverado/GMC Sierra 2500HD & 3500 (option)
Chevrolet Suburban/GMC Yukon XL (option)
Revelation Z28's Avatar
sounds like a waste looking at the stock hp rating. an LS7/LS2 swap would be better.
Old 10-20-2006, 06:34 PM
Dude, who would swap it and keep it stock? a tune with some breathing mods and it would put down more then a cammed LS2.
Old 10-20-2006, 07:09 PM
Wnts2Go10O's Avatar
get some aluminum heads and better intake and youll be set=)
Old 10-21-2006, 10:58 AM
Y2K Z28's Avatar
It'd be more trouble then it's worth. And maybe even be more cost effective in the end to go to an ls-7.
Old 10-25-2006, 11:56 AM
PowerShift408's Avatar
It'd sure be unique. Is there any aftermarket parts for that motor whatsoever though?
Old 10-26-2006, 06:21 AM
Dex
Dex's Avatar
572 is where its at
This is what it needs
Quick Reply: L18 F-body swap
