Differential fluid 4th gen TA
Old 11-08-2006, 08:29 AM
BlackBat99's Avatar
Default Differential fluid 4th gen TA
My 99 TA is approaching 13,000 miles. I was looking through my owners manual last time I changed the oil and saw that they recommend changing the diff fluid at 5000 miles! I haven't looked but is there a drain plug so I don't have to remove the cover? I really don't want to pay the dealer or someone else to do this. Why is this recommended? Is it some sort of "break in" fluid from the factory? Thx.
Old 11-08-2006, 06:00 PM
LS1Tech Administrator
RPM WS6's Avatar
Received 1,486 Likes on 1,069 Posts
13K on a '99, not bad. Same mileage as my '98
I changed the diff fluid in my '98 at 11K miles. I think it recommended it at 7500. You have to pull the cover off to drain it, then there's a fill plug on the passenger side (near top) of the diff.
Old 11-08-2006, 09:59 PM
LS1Formulation's Avatar
Invest in a T/A rear cover as well, then next time you can just take the drain plug out to drain the gear lube. I'm sure they recommend changing the fluid after 5000 miles due to miniscule metal shavings floating around from the gear break in period. When you change it out, fill it with Royal Purple Synthetic lube.
Old 11-09-2006, 02:12 PM
dailydriver's Avatar
Agree on the T/A or Mac cover, disagree on the RP in his axle. '99s had Auburns, synthetics are a in those diffs!! Use a good mineral based gear oil.
Old 11-09-2006, 02:26 PM
2001NBMZ28's Avatar
You meant '98's had Auburn, right?
Old 11-09-2006, 03:47 PM
Nope, '98s AND '99s had Auburns.
Old 11-09-2006, 03:58 PM
bww3588's Avatar
which is better? Auburn or Torsen?
Old 11-09-2006, 05:12 PM
2001NBMZ28's Avatar
www.ls1tech.com/forums/showpost.php?p=1740885 Wasn't sure exactly what year they changed, that's why I asked. Didn't SLP have a special Auburn option on some years?
Old 11-09-2006, 05:31 PM
BriancWS6's Avatar
Take off the cover, drain the fluid and wipe out the bottom with a clean rag. Clean the magnet off and clean the old gasket material off. Use some silicone and put a bead on the cover, going around all the bolt holes as well. Put it back on, pull the fill plug, and put some good ole Valvoline 80-90 gear lube in there with a bottle of the limited slip additive.
Note, it is ALOT easier to spend a small amount of money for a pump to fill the rear back up with. It's a pain to try and squeeze the bottle and fill it (been there done that ) It takes a little less than 2 quarts to fill it.
Old 11-09-2006, 05:47 PM
Yeah, I think the SSs and Hawks (not sure of the years) had the Auburn Pro available as an option.
Old 11-09-2006, 06:18 PM
RPM WS6's Avatar
My '99 didn't.
I beleive at least some of the '98s do.
Old 11-09-2006, 09:05 PM
My '98 had an auburn, but I believe from '99 up they had torsens. I blew my auburn up though, so now I have a torsen until I get a new axle.
Old 11-09-2006, 09:07 PM
silverLS199's Avatar
aint the auburn better??
Quick Reply: Differential fluid 4th gen TA
