Annoying sound from rear end?
Old 11-17-2006, 07:01 PM
roSSi's Avatar
Default Annoying sound from rear end?
Help please. It started a few weeks ago but it never really bothered me until people started pointing it out. When my car is rolling I can hear this constant sound like somethings stuck on the tire. It's a constant rotating noise. I assumed it would be gone when I got my new tires but nope... still there. Could something be broken in my rear end or axle? I'm so lost here. Any input would be greatly appreciated. Thanks in advance.
-Rossi
Old 11-17-2006, 07:08 PM
jamesSS's Avatar
just a hunch, but how is your rear brakes? if nothing else, jack up the rear and spin the tire by hand. see what happens.
Old 11-17-2006, 07:19 PM
roSSi's Avatar
Haven't serviced the brakes for a good year now. I hear it all the time though, not just when I'm braking. But yeah you just reminded me to service my brakes.. thanks. I'll will try to jack it up and take a look see when I get a chance though.. good idea. Thanks for the input.
Old 11-17-2006, 07:37 PM
JD_AMG's Avatar
gear whine?
Old 11-17-2006, 09:09 PM
roSSi's Avatar
Originally Posted by JD_AMG
gear whine?
Actually.. I have that too.
Old 11-19-2006, 08:50 AM
g-ryde1's Avatar
ima sound pretty dumb here but gear whine?
I think I might have this issue if someone could enlighten me thanks in advance
Old 11-19-2006, 05:01 PM
LS1Formulation's Avatar
Ok, I had this problem twice and it was two different things. First one was pretty bad - I broke a tooth off my ring gear and it was a constant "clunk clunk clunk". The second was a lot simpler to fix. If you've had brakes done on the rear recently and they didn't put a non-directional finish on the rotors, it will cause the caliper to ride out from the center of the rotor and pop back down repeatedly causing a noise that sounds somewhat like a rock in the tire. (imagine how a record player works, but in reverse). The simple fix is to take an air powered die grinder with a scotch disc and run it over the surface of your brake rotor. That cured my problem for me. Hope this helps.
Old 11-19-2006, 07:49 PM
KissMyWhiteSS's Avatar
I have the same problem...weird noise occasionally, I mean OCCASIONALLY. But it sounds like something is loose and vibrating when it does it. Not often at all, but when it makes the noise it pisses me off. I actually thought it was my spare tire loose and vibrating, but I tightened it down and it still makes the noise...
