turning off the auto headlights?
LS1Tech Administrator
Received 1,486 Likes
http://www.xse.com/leres/ss/drl.html
That's what I did. Works great. I hate DRLs and auto headlights. Can't stand 'em.
Copy & Paste Moderator
The easiest way to disable the auto-lights is to short together the two wires going to the sensor. You can use a "scotch-block" to short them together.
1 Post
Originally Posted by CJDZ24_Z28
There is no need to do all this. All you need to do is go to Radio Shack and by a 5 resistor. A pack of 5 cost like .69. Pop the dash in the center vent you will see a red light blinking. Pull that sensor and stick the resistor in and your done. Takes less than 3 minutes and its the 1st mod that was ever done on both of my Camaros
Originally Posted by Ell Ess Won
Take out the front of the dash/radio and take out the light sensor under the dash.
Originally Posted by VIP1
Removing the sensor without splicing the wires will make the system think its always nightime, which is the opposite of what you want.
On my Camaro I just took out the sensor. It makes ths system think its always daytime thus the lights don't come on unless you turn them on manually.
Maybe there's a failsafe when the sensor is missing.
1 Post
Use this style connector: https://ls1tech.com/forums/showt...=auto+headlight
Lift up the dash pad, it's only held by clips so it's easy. Only lift it as much as you have to unless you feel lucky.
Find the two wires to the sensor, clamp on the splice block (or scotch block) to the two wires.
Replace the dash pad.
You're done. Less than one minute's work.
Two years, no problems. Reversible in 20 seconds.
