Security Light
Basically means the car isn't recognizing the pelet in the key. First thing I'd try is cleaning the key or trying a spare if you have one. PasskeyII/VATS issue if that doesn't work.
I don't think you can do that combination, that sounds like something to do with the factory alarm or something. From what I hear the only way to correct the security light coming on is to get a new set of tumblers/key made...
Originally Posted by BAD WS6
Can you reset it by turning the key to the on position, then holding both lock and unlock buttons together until the lights flash and then stop. Will that work?
Damn, I guess I will have to find and use my spare key. Hopefully that works. Keys for our cars are not cheap either. Like $70.00-$100.00 dollars I think.
i think they are like 15 or 20 at the hardware store i work at
i dont have the car yet but isnt it just a normal motor key with a small black peice in the middle. i didnt think there was any code to it? but i know we can make them at my store for around 20 if its the same key
well we have a programmer also. ill check next time i go in, which may be tonight, but are the keys the same for all years? my friend has an 02 with the transponder or whatever its called, the plack plastic peice with a like wire on the middle of it. does this mean you cannot hook up remote start to these cars? o9r is that what the vats bypass is for?
