Warming up...?
Old 01-02-2007, 03:07 PM
El Ex's Avatar
Default Warming up...?
What is the best way to go about warming an LS1 up before runnnig it hard at all? Just start and idle for a while? Drive normal for a while? Or what?
And... Perks to FULL exhaust? In terms of doing headers of not? I'm looking at the SLP Loudmouth I... headers worth it? Performance difference?
Old 01-02-2007, 03:52 PM
MiketurboLS1's Avatar
do you mean running it at the drag strip? starting it up in the stagging lanes to move your car would be enough.
Your always going to gain power from full exhaust swap, the slp's will be fine as long as your car isnt lower, though i do think they are over priced.
Old 01-02-2007, 04:55 PM
El Ex's Avatar
No I just mean daily driving... My car is completely stock right now. I just mean how long should I let it warm up before I can get on it with beating on a cold engine? What exhaust would everyone reccommend? Price/Performance/Sound wise?
Old 01-02-2007, 05:03 PM
ohhh, well the answer to that is always going to be when the engine reaches normal operating temperatures. It's not gonna really hurt your motor by flooring it right after starting it up, its more of a cumulative effect that will wear down your plugs. As long as your changing your oil consistently it'll be fine. Like i said doesnt matter what your doing with the car, letting it warm up to proper temps is important.
Old 01-02-2007, 05:06 PM
BAD WS6's Avatar
Well said
Old 01-02-2007, 05:30 PM
El Ex's Avatar
Any answers on the whole exhaust deal? And thank you for the info.
Old 01-02-2007, 06:06 PM
i would go with a set of coated pacesetter LTs, they'll free up the same amount of power as the SLP's and without the ground clearance issues.
Old 01-02-2007, 06:14 PM
Ell Ess Won's Avatar
longtube headers are of course going to net you the single most gain with the exhaust swap. Usually 15-30rwhp depending on cat choice and your setup.
Old 01-02-2007, 08:17 PM
JohnnyC's Avatar
https://ls1tech.com/forums/showthrea...highlight=warm
Old 01-02-2007, 08:25 PM
Asmodeus's Avatar
Edelbrock Stepped Longtubes and ORY-Pipe, and a Spintech Catback
Best sound/flow combo imo without going to true duals.
Old 01-02-2007, 08:30 PM
Asmodeus's Avatar
I also don't run the car hard until the oil has reached operating temperature.
I start the car.
I let it idle until the temp guage starts moving.
I drive very easy letting the trans and diff fluid warm up.
I continue to drive easy until my oil pressure at idle has come down to 40psi.
Then I may get on it a little bit.
Old 01-02-2007, 09:45 PM
El Ex's Avatar
Thanks a lot guys! Great help! Any ideas on just exhaust if I don't do headers?
Old 01-02-2007, 09:51 PM
Camaroz's Avatar
Bounce it off the limiter to warm her up
Old 01-02-2007, 09:59 PM
El Ex's Avatar
hahaha yeah that'll do it!
Old 01-03-2007, 06:13 PM
Rede's Avatar
When I goto the track, I try to keep the temp low. There's usally 10-15 cars ahead of me (the track gets a chance to warm up so I won't have a wasted time trial if I'm the first guy at the tree = spin like a ****) so I start up the car in the pits and drive up to the line up. I turn the car off and wait fo the line to pull up a few legnths before I fire it up and pull up again. When I'm 2 cars away from the burn out box, I let it idle.
As long as I've got some temp showing on the gauge, I'm good to go.
Just don't turn the key and stand on it
Old 01-04-2007, 07:52 AM
El Ex's Avatar
HAHAHA thanks
Old 01-04-2007, 07:23 PM
parkerz28's Avatar
Get pacesetter headers and true duals, thats what i have on my car and i could tell a big difference
Old 01-05-2007, 09:21 AM
lsx24's Avatar
I think you have your answer as far as warming up goes...
As far as exhaust, that is the most important single mod you can do to your car. A good exhaust system will not only net you good hp and tq, but it will be a great foundation for future mods.
I always tell people to save up for headers and true duals, something like the Bassani Tru Dual kit. It will give you the most hp and tq possible with the ls1 engines, plus it sounds fantastic, compared to any ypipe setup. A good exhaust system with headers and true duals is a great foundation for any car.
Old 01-05-2007, 06:44 PM
Hugo_SS's Avatar
ive got the slp loudmouth exhaust, the car runs and sounds great with them, ..... some long tube headers would be a great addition to that.
Old 01-05-2007, 07:26 PM
BLKWS.6's Avatar
Normally I wrap mine in an electric blanket at night. Then in the morning I get my portable space heater and put that in front of the car while vigorously massaging the block with dryer-warmed oven mitts and cooing softly to it.
Seriously though, idle until temp guage moves, drive gently until it stops moving, by then your diff/tranny should be warmed up too. Sitting still does nothing for the diff, although it will warm the tranny fluid.
