Need Help
Need Help
Hello, I bought a 01 Trans Am a couple of days ago. I am having a little problem with it. It’s sputtering under throttle and i cant figure out why. I changed the plugs and put a new MAF on it which cleaned it up a little. The car has full exhaust headers back, stall, shift kit, and I think a mild cam. Going to try changing the O2 sensors next. What do you guys think it could be? Thanks in advance
Misfire could just be one of your new plugs/wires. The lean could be one bank, or both banks - the codes help nail it down. When you go back write down the codes, don't worry about the descriptions. In the interim double check all your plugs/wires and make sure you have a good seal on the MAF and no vacuum leaks. Did you put a stock MAF on the car?
black smoke is cause u are running rich due to exhaust system. u can have it tuned but, if u r planning to install cam I would wait for tune till cam installation. if u only get black smoke at wot I would worry about it. so as long as it's not thick black smoke.
fuerzaws6
fuerzaws6
