Reverse lights?
Reverse lights?
My reverse lights do not work. They have came on only once a while back but not since then. Is there a fuse I should check? The bulbs seem good, so I am thinking maybe a fuse if there is one to check or maybe the wiring. Any advice would be appreciated.
Well I have the same problem. I don't know how but one of the bulb fittings is rusted on the inside. So sometimes it works and sometimes it doesn't. Kind of a pain cuz people are always telling me I have one back up light out. ugh!
yea my reverse lights don't work either. it's not the fuse so it must be something else. any ideas for me and the other guys?
Originally Posted by SStheBest
check the fuses.....open ur driver side door and look below the air duct on the outside...u should see a cover for fuses....just follow along and check to see if u blew it
Originally Posted by 93transam
I didn't see a fuse for the reverse lights there. Just cig lighter, acc.'s, seats, etc... But no reverse light fuse. My car is a M6 so is there some sort of reverse connector in the tranny as well?
Actually the fuse is under turn singals/bu lights (Back Up lights). I tested the connectors for voltage with it in reverse and that was fine. The fuse was fine as well but when I tested the fuse box to see if there was voltage while hot I saw 12, so according to Chilton I have a short. Looks to me it is in the fuse box area since the connector out back has 12 volts as well.
Anymore advice on this dilemna?
