"Oil change" light
"Oil change" light
Im just wondering what makes this come on?? I change my oil regularly and it only comes on at times. Are there any certain things that make it come on? Does it go by mileage? And how do i reset it?? Thanks!
On my hawk you set it by turning the key (don't start) and hold the reset trip mileage for like 4 sec, and that resets it. As far as light coming on I believe mine is set at 3,000 miles, but I never get that far, I change my oil early. lol. Only saw the light one time when I forgot to reset it.
It's the GM Oil Life System - it's explained in the manual, can come on anywhere from 3-10K depending on your driving habits. Don't use it myself, I go by mileage. You reset it by turning the key to RUN, don't start car, press and hold the oil reset/trip button the dash until it goes off. You can also turn key to RUN and fully depress the gas pedal 3 or 4 times. Once it sets the light it should only come on for a few seconds after start up then go off until you reset it.
It's based off mileage. There's two ways to reset the light. The way I use is turn the key to the on position and then push the gas pedal three times. The light will then go out.
it will blink once in a while then eventually it will stay on. dont remember what milage this happens at but, driving habits/conditions/milage all work together for light to start this sequence.
fuerzaws6
fuerzaws6
Great! thanks for the help!! I guess its about time for the light to come on with my driving habits and the amount of revoultions i have turned. now i know how to shut it off. Thanks!!
